Question about GE Microwave Ovens
My microwave has a series of three beeps with an error code of F3. What does this mean?
  • GE Master
  • 9,098 Answers
F3 on a GE means you have a failed keypad.
But just in case, the first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 12, 2008
GE JES2150MRSA f3 code microwave turns on by itself,beeps out of control starts cooking by itself f3 is a control panel error
"F3" means you have a shorting membrane keypad.
Looking at the parts list for model JES2150MRSA, only the glass turntable and turntable support are listed, so it appears this is one of those unsupported "doorbuster" models.
If it's still in warranty, it can be exchanged. If not, it should be disposed of.
Mar 15, 2017 | GE Microwave Ovens
- "F3" means you have a shorting membrane keypad.
- Looking at the parts list for model JES2150MRSA, only the glass turntable and turntable support are listed, so it appears this is one of those unsupported "doorbuster" models.
- If it's still in warranty, it can be exchanged. If not, it should be disposed of.
My GE Microwave JES1344SK is showing the code -F3- on the digital screen and it beep three times every 30 second, the microwave won't start and any of the fuctions is working I need some help on t
An F3 code means that the touch pad has a short. The touch pad needs to be replaced. If you purchased the microwave new, get your receipt and the unit serial number and contact GE for the repair (1-800-GE-CARES). See http://repair.geappliances.com/ to find a repair center near you. There is a one-year parts and labor warranty on this part. You will need to get the unit to the GE Repair center at your own expense. (I'm assuming that the unit wasn't shorted by a lightning strike or other disaster.)
I hope this helps.
Jan 02, 2012 | GE JES1344SK Microwave Oven
F3 code
An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
On many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Aug 10, 2011 | General Electric Microwave Oven
F3 - error code, wont stop beeping at us.
Hi luvashley28,
F3 error code means that there's an open or shorted oven temperature sensor (RTD). To resolve this you have to Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
