Averatec AV6130HS won't boot beyond the BIOS? It says SMART enabled but SMART failure - but there's no SMART feature in the BIOS.
    Master:
  • 848 Answers
Backup everything, drivers, documents, media, whatever to another hard drive or CD's (or DvD's)
download active SMART
it uses SMART, and its like taking your HD to a doctor whos going to tell you how its going to die.
Posted on Jul 11, 2008
    Sergeant:
    Champion:
  • 250 Answers
SMART is storage monitoring. It monitors your hard drive for failure. You really don't want to turn it off. And it sounds like you might be having a problem with your drive. Do you get any other errors?
    Genius:
  • 3,422 Answers
Does this mean you were unable to boot from the CD, or unable to get into the recovery console? Or, did you try to do a repair installation of WinXP and you still an error of some kind?
First step I would do is to get into the recovery console and run chkdsk /r. That should at least mark any bad sectors and might be able to recover the damaged Ntfs.sys file. If not, you can extract the missing file(s) from the CD but if it's more than one or two that are missing/damaged, a repair install of windows might be easier.
To get to the recovery console from the XP CD:
http://pcsupport.about.com/od/fixthe...s/rconsole.htm
  • 6,487 Answers
Try resettings your BIOS to its default settings..........
Hope that helps...
  • 1,183 Answers
The harddrive on the unit can be causing the problem. Disconnect the harddrive and check if the error code changes.
If the error changes , it a faulty harddrive.
Second , you can reset the BIOS to factory defaults and then check for error.Also let me know if there are any beep codes that hear when the SMART error is displayed
Thanks
Proton
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
My averatec booting problem
The SMART is the monitoring system that is embedded in all hard disks - if it reports a failure it means that the hard disk has died. You need to replace the disk and only after that you can reinstall.
Jul 10, 2010 | Averatec 3200 Notebook
I have averatec 3200 boot failure how to rboot it
Boot failures are generally caused by the system not seeing the hard drive or not being able to read it. You should enter the system bios and see if it can see the hard drive or see if the system sees it while booting up. It could just have some bad files or bad sectors. Where it's in a notebook it probably doesn't have a bad connection. You can also boot off your system CD and choose recovery and see if you can see the hard drive.
Nov 07, 2009 | Averatec 3200 Notebook
At boot up, my Averatec 3150HS displays the error message "north bridge fan error, press F2 to continue" I can't find the fan.
Hello there:
boot into bios and look at the advanced section and see if the bridge fan is located there and if it is just enable it than press the f 10 key to save and than reboot the system
Aug 15, 2009 | Averatec 3150H Notebook
Suddenly getting boot failure message averatec 3200
this could be do to a bad connection to the boot device such as the harddrive.
I would try to boot from the cd rom using the OS disk.
Aug 07, 2009 | Averatec Laptop Keyboard for 3200 Series
Bios
It may be necessary to replace the BIOS IC if it is socketed and if it is not stored in flash there, you may have trouble ever accessing the password.
There might be a 'hack' to learn the password but that is out of my experience.
If you can prove the unit is yours, maybe Averatec will supply you with a way to bypass the password.
Aug 19, 2008 | Averatec AV6130HS 20 Notebook
Reset
If you mean factory defaults, you do this through the BIOS setup.
During the initial boot, a message should flash on the screen telling you which F key to push to enter Setup.
This is, on most systems, F1 or F2.
The text menu normally shows a selection called Factory Defaults or Auto Setup or similar language.
S.M.A.R.T
BIOS Setup -> Advanced BIOS Features -> HDD S.M.A.R.T. Capability -> Enabled
Nov 29, 2007 | Intel Motherboard
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
