LG 42PX5D 42 in. Plasma HDTV Logo
Posted on Jan 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My lg 42pg20r ta was working fine and was on overnight (KIDS!!) and in the morning the tv was turned off and then an hour later turned back on and there is no picture at all.The sound works fine but no picture at all on any channels.I unplugged it and moved it and now it also has a constant ringing as well.
ahmednesar
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 06, 2014
ahmednesar
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
767
Points
Hi i am from ksa any one please help me my lg tv problem is on tv rad full display how to solve
Anonymous
Level 3:
Genius:
  • Master 1,637 Answers
  • Posted on Jan 09, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1637
Questions
Helped
289972
Points
4933
Hello kurzty, please use the INPUT button located on either your remote or on the TV UNIT to change the existing input station/video. Keep cycling through the input selections until you see the regular programming again. If you can at LEAST see the menu pop up on the screen, you know nothing happened to your projection device. which means your NOT going to have to pay several HUNDRED bucks for a repair if your not under warranty. Write back if you have any more problems. My username is bbl242003
I have a LG model number 47LE7500-TA it is about 4yrs old now the tuner stopped getting channels then a month later the picture and sound both stopped working when using the Foxtel box.can fix or not
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Remove the back off the LG TV
lg 42pg20r-ta full display red color how to solve
New LG Flat Screen Plasma tv - worked fine and then when we tried to turn it on, nothing at all happened. What could the problem be? Clicker does not activate tv.
Check ur clicker like tries new set of batteries.Check the power source like the power outlet?Yes,tries tv unplug,replug the tv power a/c cord plug back like about an hour later for the tv to do resetting it seft back to the factory setting.The tv now should work again.If still have the same problems,tv have problems,new tv bought it under a year old.Call LG take ur tv warrenty repair.
2helpful
The lg 42 in tv indicates invalid format when I connect the hdmi cable but the first time I connected it was working fine I moved it to another lg tv and it works fine
Tries tv unplug,replug tv it back like about an hour later.By letting tv resetting iself back to the factoty setting.Goto Menu goto PICTURE go down to resetting to reset the whole tv tuner signal board back to factory.That HDMI port should work again now,If not that HDMI port is shorted and dead sorry.
1helpful
LG TV loses channels when turned off
Is your location prone to power surges or failures? Try plugging your TV into an uninteruptable power supply (UPS) (battery backup and line voltage conditioning). If that doesn't help, I would be suspect the unit has a problem with the internal memory.
I hope this helps.
Turns on But No Picture and No Sound
sounds like it could be a cabling issue, try replacing the cabling (if you have another tv, you can borrow the cabling before purchasing new set of cabling)
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
RCA Colortrak plus. Model# F32672SB Serial # 807560570 Chassis # CTC187CJ3 Manufacture Date Feb 1998 Service # F32672SBFM3 4/21/08- TV worked fine last night. This morning worked for about an hour. ...
It's probably a cracked solder joint in the power supply / horizonal drive stages. As the unit heats up the joint is seperating and breaking connection. It could also be a component failing when it gets hot. Usually the voltage regulator or Horizonal Output Transistor (both mount to heat sinks).
If you know how to solder and want to tinker, unplug the set for a couple days (to let the power capacitors discharge) and resolder and crystalized it cracked joints on the board(s) where the power stages, and flyback transformer are located.
If you decide to operate the set with the back off, please be careful. The high voltage on a TV can be 30,000+ volts.
Hope that helps,
Geno
Chirping noise
Sounds like something may be shorted out inside keeping the power supply loaded enough it wont start, dont recommend trying to fix unless you know EXACTLY what you are doing, there are some high voltages inside, I wold Call a TV tech out to repair, Just FYI, these sets from Phillips/MAG usually have CRT fluid getting cloudy causing discoloration/fog to pix around this age and older, between both repairs, some sets start around $1000, just an idea.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
