Whirpool top load washer
My washing machine does not always spin out all the way
  • 481 Answers
Things to check, to narrow it down:
  • is the timer stopping prematurely? (timer problem)
  • is the machine draining the water as fast as usual? (water pump problem or something blocking water flow)
  • is it spinning as fast as usual? (clutch problem)
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 12, 2008
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
Washing machine doesn't always spin after draining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 21, 2010 | GE WBSR3140DW Top Load Washer
My whirpool washer will not spin. Any suggestions?
heatman101 .
Oct 11, 2010 | Whirlpool AWM6140 Front Load Washer
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Whirpool washing machine it won't spin after it drains water
Check if there looks like black powder under machine
This would be the coupling falling a part
It is worth fixing and not to hard
The part is under $10
Jun 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Nov 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine doesn't spin spindel
whirpool part# 80040 agitator dogs need replacing remove center cap remove bolt in agitator pull top section up ..may need to hold bottom down and pull up sharply on top section to separate
Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
My washing machine do not spin
Do you have a direct drive or belt drive washer?
Oct 26, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
