Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Propane Gas Dryer (Whirlpool DUET Front Loader) not drying
The dryer is not drying correctly or completely!!! The vent is totally clear and the gas thermostat is set to High. The unit was inspected by a qualified service tech who found no problems with the unit..!!! I am @ a loss !! I paid good money for what!!! A dryer that takes 90 mins to dryer a normal load, My gas bill is much higher due to that fact also. After 18 months of aggravation I need to find some resolve. Any assistance would be greatly appreciated.
  • kchambers936 Jan 09, 2009
    I have the same problem,, it takes forever to dry my clothes. I checked everything,, vent is clear, took dryer apart, to see if it is full of lint,, nothing, it was clear. Mine is a gas dryer, that I had a qualified repair man put in a propane converter kit.. Worked great for the first 8 months,, now for the last 3 months it gets longer and longer to dry clothes.. I thought this was suppose to be a energy saving appliance. any help here.. thanks
  • raltiere Jan 11, 2009
    I have a 6 year old Whirlpool Duet gas dryer - take forever to dry clothes - is rarely hot - mostly cool - had a tech out here and seems the dryer worked for him. There is a sort of static sound from time to time. There does not seem to be lint clogging anything. Dryer does get warm from time to time.
  • 750 Answers
Huuum At your service!
Did this tech do some wash to the dryer and feel that there was no heat?
He was not a good tech
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
Posted on Oct 06, 2008
My dryer starts, gets hot..then E1.. within 2 to 3 minutes. The dryer and vent are all CLEAR of any lint..Have had my Duets since March 2002..Never had any problems at all before..What can I try next
Posted on Sep 01, 2010
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Doesn't dry clothes. New Just installed 11/16. Took 2 hours to dry a load of towels. It is a gas dryer. WGW 9450
Check vent out is clear blowing air / check clean all filters, the fact thats its new should not be anything too serious..Good luck
Nov 17, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My front loader gas Duet dryer has left brownish stains
Sounds like bad drum seals. Check all the way around the drum at the wall for sections of seals missing or an uneven gap around the drum at the wall.
Hope this helps.
Aug 14, 2009 | Whirlpool Dryers
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
Mar 21, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Do you have an idea why our 3 year old whirlpool duet gas (propane) dryer takes several cycles to dry clothes, sheets & towels? this does not seem energy efficient and why we purchased the dryer in...
the most common problem 90% of service call blocked vent dirty or crushed behind in wall also may have blockage if not a thermo stat is bad
Apr 19, 2008 | Dryers
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
1,140 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
