Question about Empire Heating & Cooling
Empire BF-30-1 Main Burner problem
When unit main burner lights it only stays lit for about 15-20 seconds.
  • griz4718 Jul 16, 2008
    Actually I fixed it by blowing out the pilot gas orifice.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
Flame sensor,just take some fine sand and lightly sand,it will be where the flame hits one of the burners,should look like a probe,if this helps please give me a fix ya
Posted on Jul 15, 2008
Richmond gas hot water heater. After I light pilot and main burner why does it flame out in 15 seconds?
If you had to light the main burner manually, something is wrong. Once you light the pilot and it stays lit, the flame heats the thermocouple to open the gas valve and fire the main burner. Either or both of the components you replaced could be defective.
Sep 10, 2015 | Water Water Heaters
Pilot lights but no main burner
Is there a way to check for gas pressure even if just a slight loosened connection to hear it then quickly re-tightened. Otherwise the main valve is not working as it should and will need to be serviced or replaced. Thats all i got.
Dec 02, 2011 | Empire Heating & Cooling
My dv35 wall furnace pilot light on main burner will not light
lightly tap on the area where the wires are connected. the valve will stick at times. try that.
Oct 30, 2011 | Empire DV-35 Heater
Empire Hearter (old unit) Model # DU 215-7SG Pilot light goes on and stay on but the main burner will not ignite.
I notice that I have the same problem and the wire coming out of the frame on the outside opposite where the thermocouple attaches to the frame on the inside goes nowhere. Shouldn't that wire connecting to something? If so, exactly where is the point of attachement of that wire? It should control the opening of the main gas value somehow.
Richard
Nov 02, 2010 | Empire DV-35 Heater
Empire uf-30-1 can you use natural gas in unit buy just changing the burner orifice size
NO! You have to change the pressure spring it the gas valve and the pilot orifice also.SET it @ 3.5WC.
Sep 15, 2010 | Empire BF-10 Mid-Size Heater
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
Heating & Cooling Logo
327 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
