Back to:
Tags:
Transceivers
Generic problem for all Transceivers
Required,mic wiring details for ft290 transciever
posted by dadoftoffee on Jul 11, 2008
ft 290 wiring details for mic.
Comment by dadoftoffee, posted on Jul 31, 2008
MANY THANKS TO ALL THE LITTLE HELPERS.
MUCH APPRECIATED,
DAD-OF-TOFFEE.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
cwd001
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
290 plug
looking at the end of the plug that goes into the 290 the pins are labelled, with the notch at the top, the connection to the right is pin 1 , counting clockwise connection 2 thru 6 (6 is to the left of the notch.) 7 centre
1mic earthand common return for up/down button via lock switch and ptt, 2mic, 3ptt, 4 +5V, 5 spkr, 6 up button, 7down button
Hope this helps
Rating Locked! (?) dadoftoffee has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on required,mic wiring details for ft290 transciever:
I don't want to Accept this solution
Can you Help with these Transceivers problems?
Jabra T-Mobile Wing / Dash / SDA / Sidekick...
My t-mobile wing phone screen does not turn on, you have...
Transceivers
Fault description: About 2 years ago, the rig started off...
my screan does not turn on, it only turns on when you...
Enterasys Distributed Forwarding Engine...
hey yoo... i want to forward my dsl port i heard that by...
Asante AsanteTalk - Ethernet to LocalTalk...
can't find printer, need help. thanks.
Loading problems.
Repair Service
Find Transceiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
