Question about Lowrance GlobalMap 3500C GPS Receiver
GPS module not responding icon say's gps module not responding, checked all connections, powers up, shows maps,but will not lock in on satellites. need help.
  • lngbdr329 Jul 11, 2008
    gps turns on normal,map appears, icon say's gps not responding i can't find any visable problem, any idea?
  • 790 Answers
Hi!
just click this links this can help you!! http://www.lowrancecanada.com/GPS%20MODULE%20NOT%20RESPONDING.htm
Thanks!
Posted on Jul 12, 2008
  • 6,487 Answers
The problem lies in the powering of the GPS Antenna, Try checking this link and follow the steps:
Hope that helps........
Posted on Jul 11, 2008
  • Mark Gil
    Mark Gil Jul 11, 2008
    Try this suggestion also
    • Ensure proper power is supplied to the unit for operation.
    • Check and clean connections between the display portion of the unit and the GPS module. Clean all connections with an anti-corrosion cleaner for electronics as needed. There may be an extension cable in use. For diagnostic purposes, bypass the extension and connect the GPS module directly to the back of the unit. This places the module only 12-16 inches from the unit.
    • Isolate the RS-232 communications (NMEA-0183) cable. This will have 4 wires, yellow/Orange/Blue/Shield. Tape each wire individually and then together if not using the NMEA communications.
    • Update the unit to the latest software version. Units initially released to operate with LGC-12S modules will likely require an update to function with the newer LGC-12W. It is also a good idea to update to the latest release if not already.
    • Reset the unit.
    Genius:
  • 3,422 Answers
HI,
Press MENU – MENU – SYSTEM SETUP – RESET OPTIONS – YES. This resets your unit back to factory settings.
  • Priya darshan Jul 11, 2008
    Please don't forget to rate or accept the solution.
    Master:
  • 848 Answers
There may be some code lost in your module so you have to contact the service center to solve this problem......
My nuvi 260w will lose satellite connection, will tell me maps not found, or will have the car icon all over the map while driving. what's up?
If you have a sim card installed make sure it is fully seated. Also make sure you have a clear sky view for the unit. Had this happen with my Nuvi50. Had it sitting in a position below the dash and it would be very erratic. Placed the unit on the windshield and it worked as it should.
Nov 21, 2014 | Garmin nuvi 260W Car GPS Receiver
My gps freezes when on speedo
Okay. I have to explain what happens when you use the speedometer option. While it is off, the GPS use using less cycles per minute to get the location from the satellites and sometime from ground beacons. When in speedo mode, it now needs more processor, memory, graphics speed and the power needed for the receiver. Now the unit is running about twice the cycles per minute to provide an accurate location to judge your speed.
How to work around this.
Best answer: Dont use this option! Its simple and you dont have to burn your noodle worrying about it.
2. If you must use it, then go into your display and map options and turn the map details and quality down. This will free up memory and CPU speed.
3. Turn tracking off. This will free up memory and CPU speed.
4. Use Garmin's mapping program to only load necessary map locations.This will free up memory space.
5. Be sure you are updated to the latest map data and firmware.
6. This can also be caused by the location of the GPS in the vehicle. On the main screen of most Garmin's, you press and hold on the corner near the icon showing the GPS signal. It will go to a more detailed screen of the satellites and signal strength. Stay in one place in an open area like a parking lot. Let the GPS locate itself first. Then relocate it where you can easily see it and you see 40% of signal or more from 4 or more satellites.
Have fun with what I gave you and good luck. VicFixx
Oct 27, 2014 | Garmin nuvi 1250 Car GPS Receiver
My gps continues to look for or acquiring satellites went through montana, yellow stone, wyoming and is still is looking for satellites. Continues to ask trouble tracking satellites are you indoors now? ...
ahhaaa If you want a wonderful lost weekend away from it all Then use a GPS.
Your main problem is that your battery is too low to find and make a connection. You may also want to check that you have the right Baud rate and port set. Check in the manual. But basically the battery is sogged.
Never plug it to the car power and start the engine and always charge with AC or USB prior to any trip.
If it can't find a satellite it will always think you are somewhere where you last were connected and because the power is low it concludes you are inside
Please rate my help++++Thanks for using FIXYA
Jul 01, 2010 | Garmin Nuvi 660 GPS Receiver
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
My tomtom only gives Guam locations
Your problem might be that the GPS can't get a lock on the satellites and it doesn't know in which part of the world it is.
I suggest you download the latest updates and QuickFix, then leave the unti close to a windows (even if you are indoors). The unit should be able to getn afix on the GPS satellites in less than 15 minutes.
Please, let me know if you need more detailed instructions.
Mar 21, 2010 | Tomtom GO 510 GPS Receiver
Show map does not show current location
im going to assume the satellites are not locked on.
look up at the top right corner of the map screen, and there should be atleast 4 green bars..if not, the satellites have not locked on to your position yet and wil show the last location you were at when i lost the satellites.
take the unit out side in clear view of the open sky and turn it on, then hold the power button for ten seconds. after it turns off, hold the power button till it starts. let it sit outside for up to 30 minutes to aquire the satellites.
if that fails, go HERE and download and install the latest update. just follow the install direction and it should fix it.
Sep 30, 2009 | Magellan Maestro 4040 GPS Receiver
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
N95 slow GPS
hey! i've found out no need to hack hardware or use a-gps. open GPS data in connectivity folder , look at satellite status and hold the phone far from your body. I always get lock in less than 1 minute. then exit GPS data and open nokiamaps. Garmin also locks faster than nokia maps, so i suspect the problem is in nokia maps sotware. I put GPS data icon in active stanby applications for quick launch.
Sep 18, 2008 | Cell Phones
check the power connections to the antenna
Aug 23, 2008 | Lowrance LMS-330C GPS Receiver
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Lowrance GlobalMap 3500C GPS Receiver Logo
992 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
