Hi.
First try repair and system restore, as stated.
If nothing else works create a different account in Windows (go to control panel>users). Create an account with administrator privileges. Log in using the new account and try installing the software from the new account. This will fix the problem in case that the troubles are given by corrupted Quicken user data in Windows.
If that does not work in some case you need to reinstall Windows.
Try all other options first.
There is a possibility that you will have to uninstall and reinstall Quicken, or obtain 3rd party help but just to see if it would help, I would use System Restore in Windows Vista Help and Support. You restore to date previous to that when the program stopped working. You will not lose any files, you will just restore your registry to a previous date and also negate many negative processes that could have affected the program.
Here is a program that claims to fix any Qucken problem, and this page has the error codes:
http://www.quickbooksfilerepair.com/quickbooks-data-recovery.aspx
This page has that link, and some other links that might help:
http://forum.worldstart.com/showthread.php?p=1450529
Here is Intuit's support page, and they may be able to assist you for free:
http://fi.intuit.com/support/
Good luck, and hope this helps.
I've uninstalled and reinstalled Quicken several times. No help. I will try the system restore after go to the quick books file repair link you suggested. I'll let you know what works. Thanks for the suggestions.
Quicken Assist is a Financial Application which allows you to control all your financial savings or loans or property or Home. It is used to preserve the documents of a company or home. It helps you control your financial records, so if you are facing any problem in your Quicken, kindly get in touch on Quicken Support Phone Number and get help from experts in the field. We provide assistance 24*7 so that if you face any issue regarding your Quicken then you get quick help and get the best support from our expert technicians. We value the time of our customers thus we help you round the clock and provide assistance from our Quicken Technical Support. https://www.quickenassist.com/
