Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Connection problems Hi, I have installed the adapter but keep getting "limited or no connection" status notices, when I go through the repair connection promt it ends with an invalid IP Adress as the reason for problem ???
  • munro276 Sep 27, 2008
    Exactly the same problem. Using a Netgear DG834N router, works fine with my PC. My son uses a Belkin wireless adaptor and although it recognises the wireless network displays the 'little or no connectivity' message.
  • 611 Answers
I think that if your ipaddress will not properly.second thing is that if your firewall is on then off that one or proxery server is there also show this message
or your dns value. if you using dhcp then you give the ip address then also not come the internet.
try this things
Posted on Jul 12, 2008
Cannot connect to open wireless network Invalid IP Address
Either the network requires you to manually configure your ip settings(unusual but not unheard of) or your wireless adapter is not set to get settings from DHCP. Check to verify that your wireless adapter is set for DHCP and if this is correct then you'll need to contact the administrator for the wireless AP and haver them check their settings.
Jan 08, 2010 | Dell Latitude D610 Notebook
Hardware problem
Connect the adapter on your computer then check the status of the device under the device manager. It should appear under Network adapters or USB Devices. double clikt its icon and look the device status. if you have the drivers installed successfully and you have tried it on different USB port, youmay try installing on another computer to further isolate the problem. If problem persist after installing it on another computer then it only means that there is something wrong with the device.
Jul 16, 2009 | Trendware TRENDnet TU2 ET100 network...
Limited or no connectivity
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Feb 12, 2009 | PLANET USB WLAN...
Limited or no Wireless connection
It appears that the TCP/IP got disabled or removed.
Check the TCP/IP settinge of the wireless adapter, it should be the same as the network adapter.
Feb 09, 2009 | IBM ThinkPad T41 Notebook
Wireless network connection
Mine always does that when my IP address lease renews but it's an easy fix. You can usually click on the pop up that says limited or no connectivity then in the box that comes up click repair. If you cannot get to that box you can just go to start>control panel>network connections then right click the wireless network connection then left click repair. That usually works for me.
Hope that helps!
Nov 30, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
I cant get onlin
I have seen this kind of strange behavior when the adapter is bad. No network detection, or connect but no webpages would ever come up, weird problems. All cleared up by replacing the adapter with an identical one, so it was not because of any settings or software issues. A new adapter is probably needed.
Nov 13, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Netgear WG111 keeps losing connectivity
not at all you will only get limited network in safe mode. you need to repair windows by booting from your windows cd and run a repair
Apr 18, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Problem in wireless connection and showing limited access
typing incorrect password weather in wireless setting or in computer
Jan 28, 2008 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Installing a 32 bit air link wireless cardbus adapter AWL C3025
First have you tested a wired computer to assure all but the wireless section is configured correctly?
Second have you tested a wireless unencrypted connection to assure it works?
When choosing an encryption strategy did you assure the router and adapter supported the same choice. Generally there is WEP and WPA -- most people prefer WPA now however both the adapter and the router must support it to make it a viable choice.
To provide further assistance please check the model number of the router and provide either the manufacturer and model for the wireless adapter or the computer with a built-in wireless adapter you are attempting to connect.
Dec 06, 2007 | Airlink (AWLC3025) Wireless Adapter
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
73 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
