Question about Quasar HQ2081QH Air Conditioner
My unit leaks
The unit leaks from the front after 15 min of use
    Scholar:
  • 148 Answers
Actually nothing major,you have to tilt your ac so the back is lower than the front,if you have it tilted already then you have to check the drain in back of the ac to make sure its not blocked,also make sure the filter is clean
Posted on Jul 11, 2008
How to find and repair oil leaks in front of motor?
Ok ralph first off clean motor with engine brite found at any auto parts stores
next recommendation add oil base dye to motor oil allow to run for 30 min to circulate dye useing a uv lamp or black light and inspect front cover most cases the front seal is themost likely source of leaks due to contant revolutions on front main seal
in order to repar suspected seal total dissasembly of timing cover will have to be removed in some models the front main bearing journal will have to be removed as well.
upon removal of timing coverbinspect front mail seal race / face for burnishing of the crank seal face. Dirt an debri cut into the crank
you will have to order the front seal repair kit
consists of front seal and stainless steel wear ring wich is glued in with epoxcy
reassemble front timing cover gaskets an sealer may be needed once all the parts are reassembled run for 15 m7n an check for leaks
its also possible that the oil pan gasket could be leaking as well
install dye to find leak is the best course of action first
Jun 22, 2014 | 2003 Chevrolet Impala
Start button take long to activate and doors leak
When you press start button the signal is sent to the main board. The leak is from a bad bellow that rubber on you door, if your door is not damage. it's not sealing with the door.
Apr 05, 2014 | LG WM-3677HW Front Load Washer / Dryer
2003 Grand Cherokee diesel - intermittent starting issues when the front of the jeep is elevated. Turns over but often wont fire for four or five attempts, occasionally will not fire at all the starts...
As when front elevated, possible small leak on fuel pipe, check connections, air getting in fuel runs back to tank, so when starting, has to pull fuel back up before starting
Mar 16, 2013 | Cars & Trucks
Just had a/c recharged and in one day it is hot air again
That's why you do a leak test, o-rings and leaks at compressor do happin,
I hope you added freon dye, or it's going to cost you freon again, when vaccuming the system for 30 min. and static pressure for 15 min.. the static is when you turn the vac. pump off for 15 min. and there is no loss of vacumn, you have to have A/C gauges, with front and rear A/C takes 46 oz freon and 13 oz of pag 46 oil, only front A/C 34 oz freon and 9 oz pag 46 oil,
Jul 21, 2011 | 2000 Dodge Grand Caravan
Hi I have Prima lv 3228p tv and there is no volume it was working fine yesterday andtoday no volume
prima lv-3228p lcd tv-after 15 mins of play the screen goes funny and there is still volume but the remote will not function. you cannot even shut the unit off, only by disconnecting the power supply. If you wait 15 -20 mins and plug the unit back in it will work for approx 15 mins again- then it will start acting up again?/
Jan 13, 2011 | Televison & Video
Leaking water tank refils about every 15-30 min.
Check the flapper inside the toilet tank for alignment or you may need to replace flush valve unit.
Sep 01, 2010 | Home
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Quasar HQ2081QH Air Conditioner Logo
125 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
