Back to:
Tags:
Parsons QuickVerse 7 Essentials  for PC
TRIANGLES
posted by GONE_08 on Jul 11, 2008
FROM A WINDOW 30 feet above the ground,a building 100 feet high, and at a distance of 200 feet, is observed.find the angle of elevation of the top of the building and the angle of depression of its base.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 04, 2008
Not Rated (0)
diggity203
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
tan x=70/200 => angle of elevation,x is ....
tan y=30/200 => angle of depression, y, is...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on TRIANGLES:
I don't want to Accept this solution
Solution #2
posted on Aug 01, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
  • FROM A WINDOW 30 feet above the ground,a building 100 feet high, and at a distance of 200 feet, is observed.find the angle of elevation of the top of the building and the angle of depression of its base.
Thank You!
Solution #3
posted on Jul 14, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
prove root 5 is irrational
Thank You!
Can you Help with these Education and Reference Software problems?
how to get the other angle and one side of the triangle...
I want to give script which automatically get computer id
square root of 1 - cos x / 1 + cos x = cosec x - cot x = 1...
Parsons QuickVerse 7 Essentials (fe11044)...
I was using QV and the screen went blank. I have closed it...
Everything seems to load properly from the cd-rom, except...
Loading problems.
Repair Service
Find Education and Ref. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
