Question about Frigidaire 24 in. FDBB840DC Stainless Steel Built-in Dishwasher
FDB834RFS0 Six lights flashing at about 1 second intervals but nothing happens other than the flashing lights
  • Anonymous Nov 22, 2008
    I traced the problem to one of the switches that is behind the handle. I jumpered across the switch and all is working except the dishwasher will not shut down when the handle is opened. It's the switch that's on the right and has the black wires attached. Be careful - one of the black wires is hot!
    Thanks, Mike
NEC VT440 projector problems can you help
Please check its vantilation fans, are they rotating or not?
Jul 24, 2008 | NEC VT460 Multimedia Projector
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
TO reset service interval-BMW320d
1. With the key out of the ignition... press and hold the left odometer button.
2. Turn the key to position 1... Meaning radio turns on, but instrument cluster warning lights stay off.
3. Keep holding the button for a few seconds (5-10) untill the display changes and says any of these words... OIL SERVICE or INSPECTION with RESET or RE.
4. Release the button but then again press it and hold (about 5-10 seconds) untill RESET or RE flashes.
5. While the display flashes press the button one more time briefly, and if done correctly the words "end SIA" will show up in a few seconds.
Dec 18, 2009 | 2005 BMW 3 Series
Sony KDF-55WF655 'rebooting'?
Replace the lamp . p/n XL-2200
Oct 05, 2009 | Sony KDS55A2000 55" HDTV
Power light flashes on and off
same happened to me i bought a new sony bravia a light flashes for six times then pauses then flashes again i had to phone retailer who replaced it theres nothing you can do.
May 19, 2009 | Proscan Televison & Video
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
Sharp Aquos 36 in. HDMI LCD
remote ceased functioning! What did I do...and how do I undo it?
Oct 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Frigidaire 24 in. FDBB840DC Stainless Steel Built-in Dishwasher Logo
65 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
