Question about Gateway Computers & Internet
Will not turn on - Gateway Computers & Internet
  • 1,498 Answers
Try the following:
Check that power supply is plugged in to a live source.
Certain models had an additional power switch on the power supply itself. This would be located to the rear of the computer within 3-4 inches of where the power cord plugs in. Make sure it's on.
Press the power button on the front panel.
Press the space bar. The computer may be in sleep mode..
Gateway desktops usually have a small 'reset' button on the front panel. Press it.
If it still doesn't respond, I'd need to know a little more info before moving forward.
  • Are there any lights lit? (K/B, front panel)
  • Can you hear a fan?
  • Does the monitor turn on?
  • What (if anything) has changed since it worked last?
  • What was the last thing you were working on?
  • What model is it?
  • What steps have you taken so far?
Mike
Posted on Jul 11, 2008
Can't turn on power to desktop
Simple power hack, to do this, kind of like hot wiring your computer.
Turn the power on at the wall, Flick the switch on the back of the computer (if there is one on the back) to the on position, make sure the cable is plugged in, and turn the power off at the wall, hold the power switch on the front and turn the power on at the wall.
This will cause the power to jump across the switch, causing the computer so sound a bit like a motorbike being started.
The power will come on it will turn over click and go off. After this turn the switch of at the back of the computer, and turn it back on, and the computer will boot up.
The first bit of this is just charging the capacitors in the power supply, the second bit is turning your computer on.
Oct 15, 2012 | Dell Computers & Internet
When i turn my syncmaster 2233 computer, it turns on but it makes a beeping sound alot of times and it won't stop.. I usually fix it by turning the power cable on and off and it will stop the beeping...
Remove the memory (RAM). Clean its contact points by an eraser. Fix it. If it does not work, try using another slot. If it still does not work,replace it with new.
sonsunny
Jun 14, 2011 | Computers & Internet
My gateway 540 gr start for 5 seconds and turn off, the fan starts to then turn off.
Disconnect everything except for the power to the motherboard. If you turn on the computer and everything still turns off, then try another known working power supply. If the machine stays turned on then connect power to your drives one at a time with the computer off each time to see which drive is the culprit.
If everything still turns off then reseat the CPU and the memory and if it still turns off then that means the motherboard is bad and it would need to be replaced.
Jun 25, 2009 | Gateway 500GR PC Desktop
Power light on front of computer is flashing - quick blinks
Most desktops require you to hold the off or power button down for at least 5 seconds, or more, before it will actually turn of the power. If you don't you won't get the desktop to turn off properly and when you try to turn it on again, you will get a message to the effect that the PC was not properly turned off last time, and it will give you the option to turn it on in Safe Mode, Safe with DOS prompt, or Safe with networking or ... finally, normal mode. If all you did was not turn the power off holding the button for a minimum of 5 seconds, then turning it on normaly is okay to do.
Jun 21, 2009 | Computers & Internet
Monitor was work'g. Turned off. In turning on pressed wrtong button. No dispaly Now
try to increase the contrast or brightness after turning it on. but check first the cable by unplugging and plugging it back before turning it on.
Apr 29, 2009 | Computers & Internet
My IBM 8183 automatically turn off while i turning it on!!
this is standard on most IBMs, when they are setup in the bios to not turn on after powerloss. you must wait for the on, then off to occur, then you can turn it on. The fan in the computer is probably loose, or possibly old, if not its normal.
Mar 29, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Every day when i turn my computer on, my firewall is turned off, so i turn it back on and make sure it is turned on when i turn the computer back off. today i can't get it to turn on.
if you have an internet security programme, sometimes it will turn off windows firewall and use it's own instead, but you should still be able to turn it back on manually through control panel>windows firewall
Sep 08, 2008 | E-Machines Computers & Internet
Wont turn on
your power supply is faulty or if youve set your comp to hibernate and it loses power it battles to turn back on . If so turn off at wall socket and watch battery light on the mother board , when it switches off turn plug back on.
Jan 18, 2008 | Computers & Internet
Computers & Internet Logo
126 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
