Question about Dryers
Kenmore dryer I have a kenmore elite dryer with a 3 prong plug. I am changing it for a four prong - 30 amps. Is 30 amps okay?
    Scholar:
  • 148 Answers
Yes 30 amps for dryers,50 amps for ranges
Posted on Jul 11, 2008
How do i connect a three prong wire to a four prong plug for 240 volts
DO NOT DO THIS.
A 3 prong plug is L1 L2 and ground, a 4 pong plug has a neutral.
If you are backfeeding a dryer outlet it is dangerous. Generator N and G should be isolated unless it is a seperately derived source
Feb 17, 2015 | GE Nema L14-30 3 Pole 4 Wire Grounding...
I have a Kenmore Elite electric dryer model # 11063932102 that will not start. It was in storage for five months and it had some superficial mice issues on the body, which cleaned up nicely, but now it...
Did you replace just the plug end of the existing cord or the entire cord/plug cable at the dryer connection? You cannot just replace the plug end since the 4th connection is not made it won't work. The easiest solutiuon is to use a 3 to 4 prong adapter. See this video that explains it.
http://www.youtube.com/watch?v=ZBJhkyHSCmo
Nov 02, 2014 | Dryers
I need to switch the power cord from a four prong to a three prong. The three prong that I purchased is a 30 amp. Will it be sufficient? Only one of the strands on the three prong is labeled. The...
30 amp. will work just fine...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 06, 2011 | Dryers
Have a kenmore 400 electric dryer, installing a 4 wire dryer to a 3 prong electric plug, now what? Can we wire our 3 prong plug from the other dryer to the four wire dryer? And how would we wire this way...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Kenmore 400 6942 Dryer
Electrical connection
yes the only difference is the four prong has a ground wire,you'll see the connector for the ground and if not ground it to the machine but there's a spot for it
Jul 17, 2010 | Kenmore 63942 Dryer
Kenmore Elite HE4 dryer- can I change the plug from the present 4 pronged utility plug to a standard 3 prong plug and still work safely?
NO, You will need to get an electrician to install a NEMA 14-30R outlet for your dryer, the electrician will know what you need, in anycase a 240V 30amp outlet is needed if you dont already have one. DONT replace the plug.
Jun 20, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Install four prong plug kit
hi thanks for the question the green wire goes to the frame of the dryer other wires red to red white to white black to black thanks the appliance doc
Sep 15, 2008 | Kenmore 62872 Electric Dryer
I need to change the power cord on our duet dryer from a 4 prong to a 3 prong The 3 prong does not have a neutral wire does that matter?
I think you need to read the following link to make sure you aren't violating any electrical codes, first:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Yes, a 3-prong DOES have a NEUTRAL wire. That would be the WHITE terminal. A 3-prong does not have a separate ground. The NEUTRAL is usually grounded at the appliance casing by a jumper wire.
Read in the "Additional Notes" section on how to convert from a 4-prong to 3-prong. Also note that some of the newer appliances require a 4-prong plug in order to run correctly. I have a Kenmore HE3 model dryer that is currently using a 3-prong power cord. Since this model Kenmore is manufactured by Whirlpool, and is identical to the Duet, you should be okay with a 3-prong plug.
Aug 08, 2008 | Dryers
Need help with plug for kenmore elite he quiet pak dryer
if she went from a 4 prong cord to 3 prong cord the only difference is a extra green ground wire... black and red to the out side screws and the white in the middle... not sure what your calling a converter... unless the changeing of the cord.. 4 prong are mostly in trailers here in florida
Aug 25, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryers Logo
67 people viewed this question
Top Dryers Experts
