There is no sound coming from my computer on either my monitor or desktop speakers. I have checked my volume controls in all of the panels and they are up but I still have no sound.
    Scholar:
  • 58 Answers
Hello.
The things you should do:
1- Make sure your speakers are on( properly connected to power supply).there should be a LED indicator ON
2- Make sure the cable coming out of your speakers or monitor ( Mini plug connector) is properly connected to the audio out jack in your computer.
Before continue:
In order to be sure all is ok, unplug the mentioned mini plug in touch the end of the plug with your finger, if step 1 is ok, you should hear a noise coming from your speaker, set the volume control in your speakers to an apropiate level, (don't forget to plug in it again).
Is everything ok ? if yes, continue:
3- In the volume controls in windows:
The left most control is the master make sure the checkbox ( Mute all) is not checked, the same apply to the one labeled wave( this one reproduce the sounds stored in your PC and the ones coming from the mic, if you are using one).
Note: to use the mic you wil have to clear the corresponding checkbox.
If this doesn't solve your problem you will have to check for the audio drivers.
Let me know if you are still having problems.
Posted on Jul 11, 2008
No sound coming from monitor.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 29, 2011 | HP Audio Players & Recorders
Sound no longer comes out of monitor. I believe nothing is muted. I replaced cable between monitor and desktop. Any suggestions.
You didn't provide a model for your Envision monitor, so I can provide specifics - but here's a few things to try: (1) Start an audio program on the computer (mp3, CD audio, movie, etc. (2) Disconnect the audio patch cable from the computer's speaker jack and plug in stereo headphones. Adjust the volume on the computer's audio control panel to set the volume. If you're not receiving any sound - make sure you're plugged into the speaker jack (this is often the green jack). If you now hear sound, continue to (3). If you are unable to hear any sounds - your problem is INSIDE the computer. More on this later. Continue to the next step. (3) Disconnect the headphones and try the audio patch cable between the computer and monitor again. Make sure you're using a stereo cable - it has 2 individual contact points on the plugs - mono cables have just two. Pay close attention to the jacks if more than one are offered on the monitor (some monitors have power output jacks, etc.). Select the "LINE IN" or "SPEAKER IN" jack on the monitor. Be sure the plugs are firmly seated into the jacks on both the monitor and computer. (4) Check the menu settings of the monitor to make sure that the speakers are enabled (or not disabled as the case may be).
if you were unable to hear audio in step (2) above, there is a problem with the audio circuit in the computer. Some things to check are: Is there a volume knob on the sound card that is turned to minimum? Are (all) the correct drivers installed for the sound card in control panel? Is the sound card enabled? Does the sound card have a problem indicated by an "x" or "!" on the icon in control panel? Many times, "uninstalling" the device in control panel and the "scanning for changes" to reinstall will solve the problem. Other times, it is an output device issue: Have you selected "Speakers" as the output (not HDMI or Digital Audio).
If still unable to get sound working, provide the Envision model number along with computer name & model or the sound card name and model. If the sound is built into the motherboard, provide the mother board name and model. With that info, it will be easier to get the info you need.
Hopefully, you got the sound working with the tips I provided above. Please rate my reply. Thanks.
May 23, 2011 | Envision Computers & Internet
No sound coming out of my hp monitor speakers. Monitor shows speakers are on and not muted. I have a green cord connected from my monitor to my desktop.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 16, 2011 | HP (PP036AA) Computer Speakers
Hi why is there no sound from my speakers
In Control panel, check you have the sound enabled by testing one of the windows sound schemes, even if you can't hear anything you will see it is enabled.
Check the volume icon on your desktop taskbar is not in mute mode
Finally, check the wire from the monitor speakers is plugged into the correct port in your sound card / chip. (Usually green)
Dec 28, 2010 | Philips 190B6CB/27 19" LCD
We brought some Sony SRS-D21 speakers for our pc yesterday but there is no sound coming through them when plugged into the rear jacks on the pc. We have test sound when plugged into the headphones jack at...
control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 05, 2010 | Sony SRS-D21 Computer Speakers
No sound coming from monitors speakers
mcdevito75 here, You can try to adjust the volume on the speakers or with the keyboard. If not, go to start on your computer, then control panel then audio devises, un-check the mute box and check the place volume icon in tray. Hope this helps.
Jun 25, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
No volume this monitor was given to me the volume is all the way up on desktop and I cant see where any speakers can be put.
Are you sure the monitor can handle speakers? Maybe it has it's own speakers, maybe it has no speakers at all. You can always plug the speakers into your CPU into the sound card, it is usually the green audio port.
That said, some things that you can trouble shoot.
  1. Make sure that the volume is all the way up on the desktop.
  2. Make sure that the volume control is all the way up in the control panel sound option
  3. Make sure that nothing has been muted, the control panel allows you to selectively mute a single device.
Apr 15, 2010 | Samsung 226BW Monitor
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
No sound coming from new hp monitor through windows vista
Alright, I got the answer for ya, first, go into your control panel. Click on Sounds and Audio Devices. Listed in this window should be the name of your sound card. Under that, should be Device Volume, and at the bottom, should be the Speaker Settings, click into Advanced, next to speaker volume. It should show you a diagram of a monitor with the amount of speakers it has selected shown next to it. Where it says Speaker Setup, click and then scroll down until you see 3 settings labeled Monitor Stereo, Monitor Stand Stereo, and Monitor Mounted Stereo. Whatever one enables the sound will be the one you want to stick with.
Feb 25, 2008 | Gateway Essential 500 PC Desktop
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
