Question about Gateway Computers & Internet
Computer will not turn on red light in front flashes
    Scholar:
  • 58 Answers
Hi.
I suggest you to be more specific
What will not turn on, only the LEDs ?
Posted on Jul 12, 2008
2008 Chevy Silverado Signal lights work in the back but not the front
when last owner put leds in it sounds like they have messed arund with the wiring, i would suggest you check that.
Nov 03, 2016 | 2008 Chevrolet Silverado
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    Hi, my ps3 wont turn on, but the red light flashes green, yellow and then red again, Whats wrong with my ps3? My ps3 will be plugged in, turned on at the back, so the red light in the front is on. When...
    i had the same problem. cost $70.00 to get it fixed. it is just temperary. 4 month warranty,it did the same thing again. an ower of a computer shop said they use to fix them, but it was not worth it. they all last that long and then would have to be replaced.after being fixed the first time.
    Mar 30, 2011 | Computers & Internet
    The red light on the motherboard is flashing
    Remove any drives and then power on, if nothing displays, replug your memory card,processor and dedicated video card if there is any. Lastly reset your bios, just remove the button shape battery and then place it back.
    Thanks for using Fixya.
    Jul 28, 2010 | Abit A17 Guru Motherboard
    My epson 3490 photo scanner isn't working theres a red light on the front of the scanner which is flashing
    If the start button light is flashing red, it is because of one of the following problems:
    • The scanner is not connected to your computer properly or your software is not fully installed.
    • The transportation lock is locked. Slide the lock to the unlock position.
    After trying these solutions, unplug the scanner to turn it off, then plug it back in.
    Sep 30, 2009 | Epson Perfection 3490 PHOTO Flatbed...
    TV won't turn on
    Count the flashes. Then we can help.
    May 21, 2009 | Sony 40 in. LCD HDTV
    My playstation 3 stays in the "standby mode" and does not turn on
    its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
    Mar 24, 2009 | Sony Playstation 3 (PS3) Console
    RED RING WHEN TURNED ON OFF FOR A WEEK
    SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
    1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
    2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
    If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
    Nov 26, 2008 | Microsoft Xbox 360 Console
    Toshibe CF32G50 - Red Flashing Light
    YOUR SET IS TRIPING MAYBE POWER SUPPLY IN TV SET
    Jul 11, 2007 | Toshiba CF32G50 32" TV
    Computers & Internet Logo
    35 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
