Question about Intel Motherboard
Trying 2 figure out what type of memory 2 use?
I have a no name computer that I need 2 add memory too. The only info I have right now is:
Motherboard Model: KM266-8235
CPU: AMD Duron 1.6Ghz
Has 4 slots of which 2 contain 256MB of memory.
Can you please assist me with my problem?
Master Bios MN31/N Award PnP BIOS
Posted on Aug 25, 2008
  • 287 Answers
That looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
AMD Athlon™/Athlon™XP/Duron™Processor
Socket 462 with FSB 200/266MHz
2 DDR266/200 Memory Sockets
6channel AC 97 Audio
2 ATA133 Channels, up to 4 ATA 133 IDE Devices
6 USB 2.0/1.1 Ports (4 ports by optional cable)
Integrated 3D Graphics Engine
Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
FSB / Transport
North Bridge: VIA KM266 ( VT8375 )
South Bridge: VIA VT8235
I/O Chip : Winbond W83697HF
2 * DDR sockets
DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
Expansion Slots
1 x AGP 4X slot (1.5V Only)
3 x PCI slots (PCI 2.2 compliant)
1 x CNR slot (AMR Type)
IDE / SATA Connectors
2 ATA133 channels, up to 4 ATA 133 IDE devices
Onboard I/O Connectors
1 x Floppy Connector
2 x USB 2.0/1.1 header (4 ports USB cable optional)
1 x CD_IN header
1 x COM (serial) port header (Optional COM cable)
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header with fan rotation detection function
1x System fan headers with fan rotation detection function
2 x 5 pin system panel header (Intel spec)
1 x Front audio header (Intel spec)
1 x IrDA header
1 x Case Open detection header
1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
20-pin ATX power connector
BIOS Feature
2Mb Flash EEPROM
Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring.
Special Feature
Form Factor
Micro-ATX (218mm x 244mm)
Posted on Jul 12, 2008
3 Suggested Answers
SOURCE: please help me in my RAM
either your ram slot is either dirty, or the slot is worn out.. it is not your windows settings.. i have the same problem with a ddr 400 1 gb chip it works.. tested with a euroshift pc checker. Wiz boy there is wrong windows has nothing to do with hardware malfunction on a motherboard
Posted on Jun 17, 2008
  • 5 Answers
SOURCE: I have an Elitegroup KT600-A motherboard (System
Hello, according to your boards manual page 38 you will have to use unbuffered memory (non-ecc) and depending on which OS your are gonna use, it might address up to 3 GBs of (SDRAM) my personal preferrence is 3x1 GBs with XP Pro 32 bits. The CPU you mentioned should work just fine, and with the added memory your rig should provide you better performance, hope this little bit of info helps.
Posted on May 09, 2009
How do I add my name to the number associated with the phone?
There should be an icon you can touch that will bring up a menu with "Edit." On my Moto G, it's three square dots stacked vertically in the upper right corner of the screen when I'm viewing my own contact info. Once you are in "Edit" mode, you should be able to add your name and other info as you wish.
Jul 30, 2014 | Motorola Mobility RAZR V3
N1 vision
On your PC or Laptop that is on the wireless network
Go to Start > Printer and Faxes > add a printer
click network printer
and then you should be able to figure out what to do, let me know how this works out for you. Good luck and if you need further help, let me know.
Have a good day
Mar 27, 2008 | Belkin N1 Vision Router
I want to add 4GB of DDR3 memory, what further info to I need to know about the memory?
Newegg has a great site to find the correct and most compatible memory for you Here.
To maximize your ram speed, use the same speed and types of ram
For example, if you have a 1GB right now, add three more 1GB than putting in a 2GB and 1GB.
If you have a 4GB ram stick right now, add another 4GB and not 2x2GB. Also make sure the MHz on the ram is the same, (1333, 1600, 2000)
Enjoy upgrading your computer!
Mar 06, 2011 | Acer AM3400U2502 PC Desktop
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
Nokia E71 - Saving new contact
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
Apr 05, 2009 | Nokia Cell Phones
I can't open my ebook library
Here are the instructions by solving this problem:
1. Right Click My Computer
2. Click Properties
3. Click System Protection
4. Click Advanced
5. Under Performances Click Sittings
6. Click Data Execution Prevention(DEP)
7. Click Turn on DEP for all Programs and Services except those I select
8. Click add
9. Under File name: type in ebooklibrary.exe click open.
Make sure that while doing this process your Portable device is connected to the computer. otherwise you will get a message telling you that ebooklibrary.exe file not found. it took me a while to figure this out. I hope that this will help.
Jan 10, 2009 | Computers & Internet
Weird (?) RAM problems (screenshot included)
First of all, make sure the ram are identical, becuase having 3 different random access memory chips in the computer can cause problems. Also make sure the ram chip is sitting in there properly. Next you should check under start go to run and type in "dxdiag".See how much memory it reports the computer has. If it reports 700etc mb,, then the one memory chip might be faulty. Also, check with the system manufacturuer, and make sure you're not overclocking the computer. Overclocking is when you put too much memory in a computer and it doesnt recognize one of the chips. 700etc mb might be the maximum your computer can handle.
Jul 17, 2008 | Computers & Internet
I would like to add my son to my aol account but I do not know how to do it. I put his name on as a screen name but cannot add him to my aol account. I do not know a lot about computers. Icannot use my...
I just saw that you posted this several times and I apologize no one helped you. This is the first time I've seen it. But you happen to get the resident AOL expert. So to add a person to your AOL account here's what you do:
1)Log on under your account
2)At the top toolbar, click on keyword
3)click on go to keyword
4)when the keybox pops up, type screen names and click on go
5)Under the screen name column, click on create new screen name (you might need to enter the answer to your account security question in the box at the right)
6)Once the box pops up for the screen name, enter the one you'd like to use for your son. Just because you choose one doesn't mean that it is available. You might want to have several he wants to choose from. After you've tried a few it will make a few suggestions for you. You DON'T have to use one of these. You can keep trying one of your own as long as you like until you find one that's available. Once you find one that's available that you want to use, it will ask you to select an age category for him. Select which ever age you prefer.
7)DO NOT check the master screen name box
8)Check the box that says I accept these terms
9)Turn on or off the AOL activity report (description on right)
10)Click the continue button
11)Enter his password twice and click next.
12)Select one of the security questions for his account and enter his answer twice. Make sure you type it the same both times.Then click continue.
13) Congratulations! It will show you the info for his account.
Make sure when you type screen names, passwords, answers to security questions and things of that nature, that you remember EXACTLY how they were typed. If a letter is capitalized then it must be capitalized. (not for screen names)
Write everything down. It's easy to forget. Don't mistake a o for an 0. I hope this helped you and told you everything you needed to add him to your account.
If this solved your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be more than happy to assist you further. Thanks and have a nice day.
May 06, 2008 | Computers & Internet
My sound
hi dear
Through the All Programs menu:
Click Start.
Point to All Programs.
Point to Accessories.
Point to System Tools.
Click System Restore.
Follow the instructions on the wizard.
Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select the restore point you just created and Windows XP undoes any system changes made since that time.
Create a Restore Point
Open System Restore. (See step-by-step instructions above.)
Click Create a restore point, and then click Next.
In the Restore point description box, type a name to identify this restore point as seen in Figure 1 below. System Restore automatically adds the date and time that this Restore Point is created.
Figure 1. Creating a restore point
• To finish creating this restore point, click Create.
• To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
• To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date you created the restore point from the calendar in the Select a Restore Point screen. All of the restore points you created and you computer created on the selected date are listed by name in the list box to the right of the calendar.
Note System Restore does not replace the process of uninstalling a program. To completely remove the files installed by a program, you must remove the program using Add or Remove Programs in Control Panel or the program's own uninstall program. To open Add or Remove Programs, click Start, click Control Panel, and then click Add or Remove Programs.
Mar 15, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Motherboard Logo
168 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
