Scanner error cc3-205-00031f04 on a mfc-465cn
  • chris3333 Apr 29, 2009
    scanner error cc3-205-00031f04 on a brother dcp-350c
SOURCE: Brother MFC-9449CN(CC3-205-03031f04) error message. Scanner
go to MY COMPUTER then to PRINTERS & FAXES and then under Other Places to SCANNERS & FAXES.
you will see the brother and right click on properties. check in the Network tab the IP address, it's probably wrong, it should be the same as the port in the properties for the printer configuration
Posted on Jul 19, 2008
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
  • 300 Answers
SOURCE: my brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Posted on Apr 18, 2010
Samyfam
  • 379 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
jay767
  • 386 Answers
SOURCE: brother MFC 465CN won't print due to "Unable to
Hi Good day!! try this method
1.pull out the AC plug
2.put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
3.now you are entering the MAINTENANCE mode and "error 46" pops up in the display
4.select 8 by using the arrow buttons ,push OK and select 0 and push OK
5.00:00 00:01 OK (the display is showing this message)
6.now push the MONO button 25 times until you see PURGE: xxxxx
7.Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
8.the purge counter indicates now: purge: 00000
9.switch off the printer ,switch it on
ready to print
Posted on Nov 20, 2010
Mfc465cn-cant print test page,error PRINTER BUSY
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: How do print network configuration page Brother In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 22, 2014 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
Jul 09, 2010 | Brother MFC-465CN InkJet Printer
Unable to print error code 4f. How do I fix?
unable to print 4F
BROTHER mfc-465cn. What is the problem and how doI fix it?
Jul 06, 2010 | Brother MFC-465CN InkJet Printer
My MFC-465CN printer will not scan. Everything
Uninstall the driver / unplug printer /re-install driver / only plug it in when instructed to.
Apr 29, 2010 | Computers & Internet
Brother MFC-465CN printer Error code 51 unable to print
Jan 20, 2010 | Brother MFC-465CN InkJet Printer
Brother mfc-465cn opening raster file failed
Try downoading the drivers from the apple web site. You would need the brother 1.1 drivers download.
Remove printer then added it again
Jan 02, 2010 | Brother MFC-465CN InkJet Printer
Mfc 465cn has black line
Open the document feeder and clean the scanner glass.
Feb 12, 2009 | Brother MFC-465CN InkJet Printer
MFC 465N - Cannot load the MFC Suite
if you follow the directions closely you should be able to install the mfc suites w/paper port brother tech
Dec 02, 2008 | Brother MFC-465CN InkJet Printer
2,083 people viewed this question
k24674
jasbo
jasbo
