Question about Casio Computers & Internet
I have a module 2471, battery is charged good. compass will not show direction and does show err when back to time display
Did you recalibrate the compass? See the manual for instructions.
Posted on Jan 01, 2009
I have an HP rz1710 pocket pc. Can't seem to get battery fully charged. It gotten worse over time. After charging overnight or all day, it still shows low battery, then displays the hp IPAQ screen with...
If the unit will work while in the charger, it is most likely the battery has reached the end of its useful life. If this is the original battery, you are quite fortunate it has lasted this long and have taken good care of it because these batteries seldom last more than a two or three years before needing replacement.
Jan 02, 2011 | HP iPAQ RZ1710 Pocket PC
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
I cant get my blackberry pearl to charge!
Yes I would take it back to your purchase place for repair or replacement. Only other way to charge is by using an external battery charger: http://www.amazon.com/External-Battery-Charger-Original-Blackberry/dp/B001MEV8LI/ref=sr_1_7?ie=UTF8&s=wireless&qid=1263336321&sr=8-7
Jan 11, 2010 | RIM BlackBerry Pearl 8100
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
No charge
I bet the battery can't hold a charge anymore. Is that battery a replacable item?
Jun 10, 2008 | Dell Axim X50v Pocket PC
Battery discharges instantly
If the LCD/Display is left on all the time, I can see that it would discharge quickly.Check any settings that have to do with power usage (LCD on time, etc)
I would change the battery still with a known good one. I suppose it is possible that the phone itself has a problem where the battery management/power management IC is haywire. Easist solution is to replace the phone.
Mike
Nov 21, 2007 | Toshiba e330 Pocket PC
Problems with extended battery
Try to check your phone if the battery connector having lost to contact the battery well. Or the problem came from your battery try to borrow from your friends battery to identify the problem.
Please rate me solved if you like my problem.
Best regards,
Philip
Nov 01, 2007 | Dell Axim X50v Pocket PC
Battery problem
preform a soft and if necessary a hard reset back info to pc first http://www.pdacortex.com/pocket_pc_sites.htm Pocket PC Sites
May 10, 2007 | O2 Xda Atom
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Computers & Internet Logo
117 people viewed this question
Top Casio Computers & Internet Experts
k24674
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
