Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Lenovo 3000 n100 won't power up
My son used my laptop Lenovo 3000 n100 and let the battery run down not in time to shut it down. Now it doesn't power up, not even plugged to the power supply. The only button that lights up is the one with the Z. I don't know if it's the battery although I doubt it. I would like to know what usually is the first thing to go, if the processor or the mother board. What can I do?
  • Anonymous Jul 28, 2008
    I have the same problem with the C200 -- just replaced charger and battery appears to be charging (the green batt light is on), but it does a half power-on with the little Z light and then off again.
  • Anonymous Aug 19, 2008
    Same problem. Twice! 1st time was 8 months after purchase. Battery apparently just died and laptop would NOT work on AC power. When plugged in, it starts up until the screen displays the Windows logo, then suddenly dies. Lenovo sent me a new battery, and it ran again. Now, 6 months later, same problem. Only now it's out of warranty and the tech I talked to this time said it might be a problem with the system board. Great, now I have a laptop that won't run on AC and paying for a new battery may not even help. Any insight into how to resolve this is much appreciated!
    Thanks and Cheers
I had posted the Aug 19, 2008 comment about having this problem twice. I tried a new universal AC adapter, and it worked! (new adapter is a Targus APA63US) Now battery is charging and laptop also runs on AC alone. So perhaps it's an adapter problem instead of a battery problem. Get one at a store with a good return policy, so if it doesn't work for you, just return it. And if it does work, then happier days. I've had mine about 2 weeks. So far so good, though with what I've learned about Lenovo since having this problem, it wouldn't surprise me if something else goes wrong, or if the damn thing just blew up, ha ha. Also, this adapter set me back about $100 that I really should not have needed to spend! arrgggh ...
Cheers and Best of Luck and hope this helps other frustrated Lenovo owners!
Posted on Sep 02, 2008
Tip
Levono 3000 n100 Notebook shuts down all the time
1. Pull out the battery.
2. Open the panel on the bottom that has the fan and remove the fan and heat sink. 3. Clean the top of cpu, 4. Put some thermal paste on the cpu
5. Put it all back together. 6. Safely dispose of the battery, If you plug the battery back in you will have to go through the whole process again 7. Run off ac adapter.
8. Buy a new battery.
on Jun 10, 2010 | Lenovo 3000 N100 Notebook
Battery shuts off laptop and won;t charge up either
Laptop batteries seem to not last too long. I see many that the owners keep the power supply on all the time, as the battery is dead. Unfortunately, the solution is a new battery. Do an internet search for "cheapest price on laptop bettery" with the make of your laptop, and be sure and look at several websites as some say they are the lowest, but others are a lot cheaper.
Aug 13, 2010 | Lenovo 3000 N100 Notebook PC
Lenovo n100 is 10 minut after power off.
If you are running on battery power and it powers off, then the battery is not fully charged or the battery is worn out or faulty.
Rechargeable batteries have a finite number of charge and discharge cycles and after 2 or more years they will lose its charge capacity until it will not charge at all.
A new battery will solve your problem provided the charging circuit in the laptop is OK.
Sep 26, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 N200
sounds like the mother board maybe on its way out - is it under warranty?
Jul 24, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My lenove 3000 N100 just keeps randomly shutting down, with full battery. what do i do?
Hello.The laptop doesn`t get hot? This is usually the problem that causes the system to crash and shut down to prevent hardware damages.
Jun 05, 2009 | Lenovo 3000 N100 Notebook PC
Lenovo 3000 Notebooks : N100 Power Failure!
Hi.. I have a temporary solution to your problem. I had the same problem. Remove the battery and the ac adapter from the laptop. Just reconnect the ac adapter without the battery and switch on the lap. Presto.. Problem solved.. It doesnt power off anymore unless u remove the ac adaptor. Usefull if u hav needed files n want 2 create a backup. Still i havent found out a permanent solution to this problem. I suspect its a motherboard fault
Jan 22, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Battery problem
SreeSatya,
Laptop batteries have a limited lifespan. When they reach the end of that life, this is how they behave. How old is your laptop?
I just replaced my Toshiba after three years. Unfortunately, laptop batteries are not cheap. You can find batteries for your system here:
http://www.atbatt.com/laptop-batteries/b/Lenovo/m/3000_N100_0768.asp
Jun 06, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
691 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
