Question about Whirlpool Dryers
Dryer turns off and shows the code E1 - Whirlpool Dryers
  • 254 Answers
E1 is open thermister
Posted on Jul 11, 2008
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
Kenmore dryer error code e1
The E1 code on this dryer indicates that you have an "open" (defective) thermistor (temperature sensor). Replacing this part will likely fix your problem. What is the model number?
Nov 12, 2012 | Dryers
Dear I have samsung dryer model jv665jw , it starts for 3 seconds and stop , on disply it show error E1 ! What is the problem please ?
It's a error code and you can call your local appliance store and give them the code they should be able to tell you what it is that's setting that code. I think E1 is the control board and usually runs in the $200 range to replace. Hope it's a simple fix though.
Apr 29, 2011 | Samsung Dryers
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
I'm getting an E1 signal from dryer...What is the
This usually works to unlock the E1 code
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal buttonfor 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked light is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked.
If this worked for you don't forget to give me a ranking. Thank you!
May 06, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Kemore he3 dryer error code E1
Hey fookie you need a thermistor for that dryer. It runs with no heat ?..Let me get a pic for you it is about 25 bucks oh and is part 42 on the pic below
Oct 23, 2008 | Dryers
ERROR CODE E1 MODLE #GGW9200LW O
E1 error code is for the thermistor, try cleaning off the bottom of the thermistor, (sometimes tacky lint will coat them), if that doesn't help, just replace the thermistor.
Sep 17, 2008 | Whirlpool GGW9250PL Gas Dryer
Dryer turns off and shoes e1 code
E1- Thermistor open.
It monitors the exhaust temperature, and cycles the heater relay on and off to maintain the desired temperature.
It could be the sensor, or electronics.
May 08, 2008 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
