Question about Sonicwall TZ 170 NFR (01-ssc-5564) Firewall
HOW DO I GO ABOUT VPN
Please can u teach me how to configure vpn using pix
  • Michael Ortega
    Michael Ortega May 11, 2010
    You just need to match up the IPSec configuration.
    Configuring your IPSec tunnel on the Sonicwall is pretty easy but by default the SA values are different on the PIX.
    How familiar are you with the IOS commands on the Cisco?
    Guru:
  • 829 Answers
Hi , Try the below link which can help you.
http://www.secmanager.com/how_to_configure_pix_firewall_part1
Posted on Jan 06, 2009
How to setup VPN on iPod?
connect to WiFi.
Tap General>Network>VPN>
you can try these settings I've used before:
Add VPN Connection. chose PPTP.
Give it a name under description.
Encryption Level:Auto
Send all traffic: ON
Proxy: Off
RSA SecurID: OFF
Here's the part that differs from the VPN I personally set up.
Server: enter the IP address of the VPN Server. this is specific to you, as to what server you want.
Account: Enter username and password to log in. If this VPN is for school, it would be your school username and school password you normally use.
The VPN at my school worked when I connected to their wifi and then turned on the VPN. for added information.
Jan 21, 2015 | Apple iPod Audio Players & Recorders
Tip
How to unblock sites in iPad or iPhone
The most secure and reliable way to open blocked sites in iPad or iPhone is using vpn. You do not need any specific application for this. You can simple make a new vpn connection on your iOS device with standard iOS features.
All you need is setup vpn connection following simple steps below:
To make a new vpn connection in your iOS device you need to do the next:
  1. Go to Settings > General > VPN
  2. Click Add VPN Configuration
  3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Under the vpn connection you can access any blocked website and be absolutely sure that you are safe and secure.
Sahrzad VPN How to Setup Guides
on Sep 14, 2015 | Apple iPad Tablets & eReaders
Why when i tried to browse to any website using safari or baidu the vpn unlimited block the website i need to see thats why i cannot open a new tab,do you have a solution for this please help me
try to download Hotspot Shield app to you iPhone and activate it, but its limited and you have to buy license to continue using it..
Mar 28, 2014 | Apple iPhone 5S
How to set vpn on ipod 8gb
  • 1 Tap the "Settings" icon.
  • 2 Select the "General" option.
  • 3 Tap the "Network" button.
  • 4 Select the "VPN" option.
  • 5 Select the "Add VPN Configuration" button.
  • 6 Select the tab that corresponds to the type of VPN network you are trying to connect to. You can select "L2TP," "PPTP" and "IPSec."
  • 7 Enter a description of the VPN" in the "Description" field. Enter the IP address of the VPN in the "Server" field and enter your VPN user name in the "Account" field. If you use a password to access the VPN, enter your case-sensitive password in the "Password" field.
  • 8 Tap the "Save" button located in the upper right corner to save your VPN settings.
  • 9 Move the switch located to the right of "VPN" to the "On" position. Your iPod will automatically connect to the VPN network.
  • Mar 29, 2012 | Apple iPod touch
    I have two Cisco routers one is a 501Pix(located at branch Office), the other is a 515E Pix (located at main office). I've configured a vpn tunnel to the router at the main office. The router at the branch...
    1. Please check whether the Tunnel Phase 1 and Phase 2 are Up.If Not Proceed Next, if Yes Proceed to point 4
    2. Please check the peer IP is reachable
    3. Please check the configuration and the encapsulation method used
    4. Check whether in the Match Address whether the IP has been Allowed If Yes Proceed Next
    5. The Branch PIX will be in the Outside interface of the Main PIX, security Level will be enabled so do NAT. If Yes Proceed next
    6. If unable to ping enable the Inspect ICMP in the global policy to enable ping If Yes
    7. If all The above are done. please check the routes between the 2 remote computer.
    Please check all the above point, surely your problems will be solved
    Feb 26, 2011 | Cisco PIX 501 Firewall
    I have an older Cisco PIX 506 with two VPN connections. One links two offices (PIX-PIX VPN) together, another is for staff to access email & files. The file server on the local LAN the PIX is on are...
    It could be a missing route... are the file server and email server on the same subnet? If they are then it is possibly not a routing issue.
    Also it would be worth checking the tunneling settings for the VPNs... if you have specifed either only the fileserver subnet or specifically the file server address, then this could be the reason they can get to nothing else.
    Hope that this has helped a little :)
    Apr 09, 2010 | Cisco PIX 506E 3DES/AES bundle (chassis,...
    How do I set up a VPN connection with PIX 501?
    No worries. Just give it a try then let us know should you get any problems or follow-up questions.
    Oct 15, 2008 | Cisco PIX 501 Firewall
    Site to site VPN between Checkpoint UTM 1 R62 and Cisco pix /Netscreen
    I couple of points:
    PIX has a few dislikes...
    1. Pix does not like class A address, make sure you are using B or C.
    2. The VPN subnet always has to be differant to the LAN.
    3. Has to have a working DNS server.
    4. Add static route, and last resort to main ethernet port that has the DNS & R62. (or 2 if on differant sub)
    Hope this helps.
    Dec 16, 2007 | WatchGuard Technologies Firebox X5000...
    Setting up a VPN through watchguard
    The key with any VPN solution is to make sure that the configurations on both ends match. I am not very familiar with this particular product, but it looks like you need to have the proper VPN licenses installed first. There are two types of VPN you can do. 1) Site to Site - This is where the are two static boxes that you want to create an encrypted tunnel between 2) Remote User access - This is where mobile users connect to a central site over an encrypted tunnel from their home or on the road. Next, take a looks at the User Guide PDF here: https://www.watchguard.com/help/documentation/soho6.asp Chapter 10 tells how to configure the VPN on the Firebox side. You would just duplicate your settings if your doing option #1. Chapter 11 tells how to configure the VPN on the client side. This section would tell you how to configure the client software for option #2. Hope this helps.
    Aug 29, 2006 | WatchGuard Technologies FireBox SOHO 6...
    Sonicwall TZ 170 NFR (01-ssc-5564) Firewall Logo
    125 people viewed this question
    Top Sonic Computers & Internet Experts
    Gopi Venkatesan
    Gopi Venkatesan
    Are you a Sonic Computer and Internet Expert? Answer questions, earn points and help others
