Question about Sanyo PLV-Z4 Multimedia Projectors
Projector question i have a projector, just got a new lamp for it since the other one burned out, and when we installed it, the projector immediately said that it needs a new bulb. It still shows a picture, but i am not sure if it is a problem with the projector or the the bulb. Is there a chip or something that has to be reset when a new bulb is put in?
  • gs expert Jul 23, 2008
    it happen t o me
  • 3 Answers
RTFM - you are supposed to reset the bulb replacement indicator in the menu.
Posted on Aug 01, 2008
I installed a new lamp in an Epson emp 61. I had a smell of something burning then the lamp went out again. whats going on?
there is some smell when you use the new lamp,the first time
and it will becoming normal after sereval hours
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jan 18, 2011 | Epson Replacement Lamp ELPLP30 f EMP-61...
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
I have infocus LP120 and the bulb burned out the other day. I installed a new bulb and it starts up fine except there is burning smell from the vent. Is it normal? Some guys told me it's "burn-in" process...
Yes it is normal, but there were issues in the past with the lamp burning the lamp cables. Infocus then upgraded the cables with slightly heavier gauge wire and better thermal tape around the wires. It would be hard for me to tell you if yours has the upgrade, but if you got it from Infocus I'm sure it is good.
Aug 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
When turning it on, the lamp light starts to flash red, what should I do? The power green light also turns red and it won't do anything...
This means that the lamp is burned out, not installed properly or the lamp cover might not be closed. Try to reseat the lamp, make sure that you close the over properly. If that fails buy a new lamp.
Apr 06, 2010 | Epson PowerLite® 83c LCD Projector
Benq 6200 shuts down immediately
did you reset the lamp timer? also may be the ballast.
Sep 28, 2009 | BenQ Office Equipment & Supplies
New lamp won't light
I am having the same problem now. I am currently trying to reset the timer...but have yet to successfully. But I do think this is the solution.
Jun 10, 2009 | Sharp DT-100 Multimedia Projector
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
NEC VT695 (not a vt570) bad lamp blowing ballast board?
We have the same model here at our school too. I know of two that have done exactly what you said. I am trying to figure out if this is NEC fault. Bulbs are expensive and if the projector and NEC is a fault; we will definitely be moving on to a different brand.
Oct 03, 2008 | NEC VT570 Multimedia Projector
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
Sanyo PLV-Z4 Multimedia Projectors Logo
150 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
