Question about Dell PowerEdge 1600SC Server
Opening the case to increase memory on Poweredge 1800
If you could be so kind to tell me how to open the case of my poweredge 1800 to add the memory chips I have purchased. I replaced the memory on three other computers in my office, but I am unable to see how to take the case off of this model...thank you, Jack
  • Anonymous Mar 28, 2014
    need to remove case to install new hard drive
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
First, turn off the system including any attached peripherals, and disconnect the system from its electrical outlet.
1. Using the system key, unlock the front bezel.
2. Slide the latch right and pull the top edge of the bezel away from the front panel. Pivot the bezel downward until it is at an angle to the panel. Remove the bezel from the slots on the panel.
3. Loosen the three thumbscrews on the left side of the cover.
4. Grasp the cover at both ends and slide it towards the front of the system. And lift the cover away from the system.
5. Press the release tab on the front and back of Fan 2 assembly, then slide the fan assembly (black plastic shroud) up and out of the system
6. Disconnect the power cable for the Fan 2 assembly from the system board.
You can now access the six memory slots. Review System Memory / General Memory Module Installation Guidelines and carefully install the new memory modules.
I have provided some pictures below to help you.
Mike
Posted on Jul 12, 2008
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
How do i enter in safe mode on my poweredge 1800 ?
If the server is running Windows, you can usually enter safe mode by repeatedly pressing F8 after you press the power switch.
You can also get into the dell utility, which lets you run memory and system tests. To access this, follow the on screen directions during boot up.
Jan 25, 2011 | Dell PowerEdge 1800 Server
Video card that supports Dell PowerEdge 1800
It says it has an embedded 7000m chip, there is no mention of a graphics slot for a discrete add in card.
Some info here http://en.community.dell.com/support-forums/servers/f/956/t/19274842.aspx
Sep 30, 2010 | Dell PowerEdge 1800 Server
PowerEdge 1800 Server: I have a Dell power edge 1800 that was used as a s...
yes you can do that but you need the drivers for the scsi interface. when you install windows xp (for example) i think you may have to press the f6 key on the installation to add these drivers.
Otherwise, installation wont take place.
May 17, 2010 | Dell PowerEdge 1800 Server
No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
May 02, 2010 | Dell PowerEdge 1800 Server
Opening the case of the Poweredge 5000SC
You would need to unscrew the thumbscrew located on the right side of the rear panel, press top and bottom cover release tabs and pull the cover toward you. To replace, perform the steps in reverse.
Good Luck
C2Solutoins
Jan 25, 2010 | Dell PowerEdge 1600SC Server
Hello, my dell poweredge 1800 does not see up than 256MB RAM, how I can fix it? I have 1GB RAM on the board...
Check the RAM frequency of the RAM which should be compatible to the main board. also chk for the other RAM frequency also
Nov 20, 2009 | Dell PowerEdge 1800 Server
Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Jun 10, 2009 | Dell PowerEdge 1800 Server
Flashing redlight on the front
Yes. Here are some things that could be an issue:
a problem with power supplies, fans, system temperature, or SCSI hard drives.
Install the Dell Open Manager software to run diagnostic. It will tell you what needs to be fixed.
Apr 29, 2009 | Dell PowerEdge 1800 Server
Available memory limited to 256
Turn off the option n the bios where it says OS Installed make sure it says os not installed
The Bios will only use 256 ram
Sep 04, 2008 | Dell PowerEdge 1800 Server
Dell PowerEdge 1600SC Server Logo
4,050 people viewed this question
Alun Cox
