Question about Black & Decker D2020 Iron
"Standby" on Digital Screen
Apparently, I accidently overfilled my Iron with water.  Now, I have this "Standby" on my digital screen, and the Iron will not heat.  But, everything else appears to be fine.  How do I resolve this problem and get the heating element to cut on again?
    Champion:
  • 217 Answers
You should be able to dump the water back out of the hole where it gets filled. After that, I would leave it unplugged for a minute to reset itself. Also try setting the controls to "off" or the lowest temp possible, before plugging it back in.
Posted on Jul 11, 2008
    Master:
  • 848 Answers
Your thermostat might have been damaged ...so try to replace it so that the your iron will heat properly
    Sergeant:
    Champion:
  • 417 Answers
Leave It Out To Fully Dry Dont Plug In or You Mite Damage The Chip Board
Shark troubleshooting
Pour all the water out of the iron, and fill it with white vinegar. Heat it and let it spit vinegar for a while.
Chances are there is simply a bunch of crud in the iron from the water, most likely calcium carbonate. The vinegar is the cheap and easy fix, but if that does not do it you;ll have to bring out the "Big Gun" and use some "CLR" cleaner, available at most grocery or hardware stores.
"CLR" stands for "Calcium, Lime and Rust", and a small jug of it is about $6 USD, It will clean the crud out for sure.
Ironing seems to be a "lost art". Congratulations on being a smart desser!
Jul 26, 2014 | Euro-Pro Shark GI490 Iron
My ultra T-fal iron is leaking right out of the iron, before I turn it on. Should I get a new iron, or can this be fixed?
I believe there`s faulty construction'and the cost to repair is about as costly as a new purchase.The valve that inhibits the water flow apparently is remaining open.
Mar 04, 2013 | Irons
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
Jun 20, 2011 | Hamilton Beach Steam Storm 14560 Iron
Water keeps coming out after pressing steam button
hi i have just looked this information up and apparently that using 100% distilled water can cause your iron to spit and leak, to solve this problem you should press the steam button and keep pressing it until there is no water left in the iron, then try it again, if it still does this, repeat a few times and then the iron should be fine
hope this helps
Feb 28, 2011 | Rowenta DG5030 Iron
My iron is spitting water when i put steam on???
It is overfilled with water. There's right measure for
your iron. It is specified in your manual. If no manual,
just fill it halfway and set your thermoswitch at a little
over half also.
Oct 05, 2009 | Rowenta DG-920 Iron
Digital revolution iron squirts brown water onto my clothes
Try an iron cleaning fluid or crystals. you can get the stuff at wallmart or similar stores. It usually works. Try using distilled water in the iron.
Jul 27, 2009 | Irons
Goo on iron sole plate of new iron
let the iron cool completely, use #00 steel wood with dish washer detergent. rise it off with clean water.
May 13, 2009 | Euro-Pro Shark GI490 Iron
I have a Digital Advantage iron, the cleaning prompt comes on and I don't know what to do, thank you
I think you need to fill the water chamber almost to full, plug the iron in and rotate the steam dial all the way to the left. There is a "clean" setting. The iron will splutter and drip water and produce steam. This is the cleaning process. You can probably have the iron on any settinng. I hope this helps.
Jun 26, 2008 | Rowenta Professional DX8800 Iron
Black & Decker D2020 Iron Logo
387 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
