Changing fluid in CRT's
OK, I've googled for days and need to know the easiest way to change the fluid in my magnavox CRT's. Any suggestions?
  • 8,617 Answers
You can go to the following site, under the repair kit catagory they have a CD that documents the step by step proceedure for coolant change in phillips / magnavox tvs with pictures. They also have the entire kit with 48 ounces of high purity coolant and the cd
Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 12, 2008
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
    www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
Magnavox model # FP4630 W104 manual
GOOGLE THE MODEL NUMBER WITH MANUAL AFTER IT IF YOU NEED THAT.
In the TV menu make sure under audio speakers are switched on.
When you try to change the volume do you get a display on screen?
If the vol buttons on set work the issue is with the remote itself.
Let me know as much as you can so I can help
Mar 16, 2012 | Televison & Video
I've changed my Toshiba AC100's language by mistake to Russian and can't change it back. If I go to Settings, can you indicate how many columns down for me to click in order to get the language...
The easiest thing to do, is open up your webbrowser.
When you see russian text, just copy & paste it in Google translate.
http://translate.google.com/#ru'en'
Sorry, but i dont know how many colums down..
Jun 21, 2011 | Toshiba Computers & Internet
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Need to fix the color and screen
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Yellow tinge in picture how do I change the coolant fluid?
you need to remove the CRT from the set. the problem CRT is the blue CRT. after removing the gun leave the yolk inside. there is a drain plug on the side of the CRT remove it and drain into a hazard waist container and dispose of it as hazard waist according to your local regulations (ethylene glycol) very dangerous if ingested. use rubber gloves and becarefull of the CRT it can implode. after its drained you must take the lens assembly off the clean the CRT face. use 95% rubbing alcohol to clean the face and lenes of the gun. replace the lens assembly and refill the chamber with fresh fluid. replace the CRT assembly in the set. alien according to the service manual. check for leaks after warm up. if leaks accure remove the CRT and repeat the process but save and re-use the fluid reseat and clean all gaskets and make sure the screws are tight.
Feb 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
I am preparing to chang the fluid on a Magnavox FP4650 W102 Projection Screen Television. The blue and green have mold and the red is clean. I am looking for a manual on the correct procedure to change the...
Be sure to change the seals & coolant...have parts in hand before dis-assembly...you will need the service manual for
your chassis / model...google search ......................T.
Feb 08, 2008 | Televison & Video
Red picture cannot adust with convergence
You have bad CRT Fluid, the green and Blue tube need the fluid changed. This is a messy and possibly dangerous to the tv proposition, you will want to call someone to change the fluid, you will probably spend $450+ for the repair, but it should look pretty good when done, possibly better than it has looked in years.
May 27, 2007 | Philips 9P5034C 50" Rear Projection...
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
