Question about KitchenAid KCM514 Coffee Maker
Err 2 My coffee pot is flashing err 2...can you tell me what is wrong?
  • healman Jul 12, 2008
    I also have the same problem. I am flashing err 2 as well. I overflowed the corafe and shortly after this the error flashed. Will this clear itself after it has time to dry out? I don't see that any coffee would have got into the system.
  • 145 Answers
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
My Survival Guide To The Dreaded Err2 Disaster
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Thank you, have a nice day.
Aug 30, 2009 | KitchenAid KCM511 Coffee Maker
Kitchen aid coffee pot says error 2
Jun 09, 2009 | KitchenAid Coffee Makers & Espresso...
Coffee pot does not work at all model KCM511ER-1 THE DISPLAY shows Err2
Apr 18, 2009 | KitchenAid KCM511 Coffee Maker
Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few seconds.
Apr 07, 2009 | KitchenAid KCM511 Coffee Maker
Coffpot saying err2
Apr 03, 2009 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee pot won't brew coffee reads err2
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Mar 13, 2009 | KitchenAid KCM511 Coffee Maker
Err4 message
On a Kitchenaid coffee maker, ERR 4 indicates a stuck button. Please double check to make sure none of your buttons are sticking in place and "freezing" the coffee maker. If you can not find any obvious problems, I would recommend calling Kitchenaid Customer Service to see what options may be available to you.
Their toll-free phone number is 1-800-541-6390.
Feb 06, 2009 | KitchenAid KCM511 Coffee Maker
Err nessage 2
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Aug 19, 2008 | KitchenAid KCM511 Coffee Maker
Re: KitchenAid Coffee Pot
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Coffee pot
ERR 4 simply indicates that the computer is recognizing a stuck button (a button have been depressed for more than 10 seconds time). Please double check to make sure that no buttons are still depressed into the machine.
May 27, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
KitchenAid KCM514 Coffee Maker Logo
223 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
