I try to run Nortons security centre as demanded as "one item is affecting your status" 2 hours later the computer has completely ground to a halt and the only option is to reboot. Paul
    Sergeant:
  • 329 Answers
Can you remove nortons in the add remove program? Then try to install. Also in the search windows type in nortons and delete what comes up, Also synmantic (I think this is how it is spelled) and remove any thing that pops up. Norton is OK but for the money there are better..
Posted on Jul 11, 2008
Status light blinking
Please do a full clean up of the machine after checking in all the connections to the mains panel.Please check this link for tips to go about:http://www.espares.co.uk/advice/dishwashers/a/3/174/cleaning-your-dishwasher.html
Mar 12, 2012 | KitchenAid KUDS01IJ - Multiple Color...
Tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Samsung LA32A450 32 in. HD-Ready LCD TV
Tip
Boost your computer performance
<p><span> <p>Your computer's performance mainly depends on the "Processor" and "RAM" availability. I am sure that whatever computer you have is capable enough to run your normal daily tasks smoothly. It should not stuck or freeze while checking emails, writing documents, watching movies or songs, printing or doing business online. These are some very basic tasks and require minimum resources to execute. Any computer with a normal system configuration should work them out easily, but we still face sluggish performance or freezing up while doing these tasks.<br /> <p> The reason behind this is the processor and memory status of your computer at that time. You can check the real time status from "Task manager" which you can pull up by pressing "Ctrl + Shift + Esc" key on keyboard. Following steps would optimize the processor and memory uses of your computer and make it more efficient:<br /> <p><br /> <p>&middot; Check running processes at background:<br /> <p>Every application we use has several processes running in background to make it work. Sometimes we are not even aware of the extra unwanted software or applications which start automatically and keep running in background and eat up our processor and memory usage. This you can check by Task manager's "processes" list. Also some of these applications show their notification icons in "system tray" area which is where you see the system time on your desktop. Try to keep minimum application running in background and this will make our system smooth as it will have more resources to utilize.<br /> <p>Follow the below steps to disable unwanted applications:<br /> <p>1. Click on "start", click on "run" or press "Flag key + R" from keyboard. Type" msconfig" on the "run" window and hit "enter".<br /> <p>2. This should bring "system configuration utility" windows on screen.<br /> <p>3. Click on the "startup" TAB on the top menu. This tab holds all applications which start automatically when you turn on your computer.<br /> <p>4. Check the list carefully and uncheck the ones you don't need.<br /> <p>5. If you are not sure about some application, type its name in google search, figure out its use and decide to whether you want to keep it running or disable it.<br /> <p>6. Once you are done with the List, click on "Services "tab on top.<br /> <p>7. This "services" tab holds all important programs which give a platform for other software to work.<br /> <p>8. Check the box in bottom which says "Hide all Microsoft services".<br /> <p>9. Now you have the list of non-Microsoft programs running in background. Some of these might be you antivirus software, backup software or messengers and others may be unwanted ones.<br /> <p>10. Identify the not required items and uncheck them.<br /> <p>11. Click on "Apply" and then "OK".'<br /> <p>12. It might give you a windows asking for "restart computer" or "Exit without restart ".<br /> <p>13. Choose "Exit without restart"<br /> <p>14. Close all other windows make sure none of you important files are open and then restart your computer.<br /> <p>15. If later you want to enable any services back, just follow the same process and "Check" them in the list.<br /> <p> <br /> <p>&middot; Keep track of free disk space on root drive:<br /> <p>Free space on root drive (mostly c :\) is very important as this space is used for virtual memory or paging, hibernation and other system requirements. Ensure that at least 3 - 5 GB space should be available on root drive. If you have less than this, delete some temporary or junk files from "temp" and "%temp%" folders.<br /></span><br />
on Jul 19, 2011 | Computers & Internet
I live in Italy. I tried to download Microsoft Security Essentials, but continue to get the message that the Microsoft.com website is unavailable. I made a copy of the Microsoft Security Essentials folder...
Hello, good day.
1. Uninstall any existing antivirus including anti-malware software from your computer.
2. Remove the MSE folder from "Program files" folder that you copied from your friend.
3. Restart your computer (shutdown and wait for 30 seconds, then switch on your computer).
4. Logon with your usual login credential.
2. Download MSE. Browse this link http://www.microsoft.com/en-au/security_essentials/default.aspx.
3. Click the download link and follow the instruction.
This should complete your installation.
Aug 22, 2011 | Microsoft Security Essentials
My Xerox Wokcentre 4260 is stuck on one job. Some pdf file prints first 4 pages and then just sits there not doing anything, and the job still have "printing" status, and blocks all other tasks....
Solution : Perform an On Demand Image Overwrite (ODIO) Image Overwrite Security protects against unauthorized retrieval of confidential data from the machine by removing image data that is left when jobs are processed. When started, all of the physical areas of the hard disks holding job data are overwritten with a series of alphanumeric patterns.
There are two options for On Demand Image Overwrite: Standard and Full Overwrite. Standard ODIO will overwrite all jobs stored in image data as well as fax card image data. Standard ODIO will not overwrite fax mailbox, Poll store (mailbox 0) and dial directory information, or folders created with the Store Job feature, if these features are installed on the machine. Standard overwrite takes about 30 minutes. Full overwrite takes approximately 160 minutes to complete.
NOTE: Full ODIO will overwrite and delete all fax image data, including mailboxes, Poll store and dial directories on the fax card. Full ODIO will also overwrite any images that have been stored in folders created with the Store Job feature. When On Demand Image Overwrite is initiated, the machine is taken offline until the overwrite is completed. Any existing jobs in the queue are terminated, including print, fax and LAN fax jobs.
NOTE: Overwrites can also be performed on a per-job basis, immediately after each job has been processed, using Immediate Image Overwrite. See the Related Items below for additional information.
CAUTION: The machine should not be in Diagnostics mode when the overwrite is started. (The Touch Screen indicates a status of "Diagnostics Mode". This mode is used by Customer Service Representatives when servicing the machine.)
Do not power off the machine while an overwrite is in progress.
To perform an On Demand Image Overwrite from the Control Panel:
  1. Access the Tools screen. See the Related Items below for additional information.
  2. Select [Security Setting].
  3. Select [Image Overwrite Security].
  4. Select [On Demand Image Overwrite].
  5. Select the [Standard / Full Overwrite] button to switch between the two options, and select the required option.
  6. Select [Overwrite Now].
  7. The Overwrite Confirmation screen will be displayed. Select the [Overwrite] button to begin, or select [Cancel] to cancel the On Demand Image Overwrite. The machine will be taken offline and will be unable to receive any incoming jobs. The Image Overwrite will proceed to overwrite all image data on the hard disk.
    NOTE: If Embedded Fax is installed, all Embedded Fax compact flash data will also be overwritten.
  8. When the overwrite is complete, the On Demand Image Overwrite completion screen will be displayed.
  9. Select [Close]. The Disk Overwrite Confirmation Report will print. This details the status and time of the overwrite. The Network Controller will then reboot and network functionality will be unavailable for several minutes.
    When the machine has rebooted, verify that the overwrite operation has completed by viewing the Confirmation Report (under Confirmation Details). The Job Information: Status ESS Disk parameter should read "SUCCESS".
Apr 15, 2011 | Xerox WorkCentre 4260/S Multifunction...
Tip
How to restore computer to a back date
<p>Restore feature of Windows provides a point of safety net against catastrophic failure of the system regularly save the computer status. You can store, known as "restore points" that the damage in the event of a severe infection of malware, drivers, system file corruption or hardware. Once called to re-establish this point, the computer returns to a previous state, but not without some affected programs. Access to the system restore feature is a simple process.<br /> <p> <br /> <p>1. Click "Start" and type "System Restore" in the search box.<br /> <p><br /> <p>2. Click the "System Restore" to lead.<br /> <p><br /> <p>3. Enter your admin password to be asked.<br /> <p><br /> <p>4. Click the "Recommended restore", click next.<br /> <p><br /> <p>5. Review the list of programs and files that will be affected, and click "Finish".<br />
on Jun 21, 2011 | Computers & Internet
Tip
Error on HP solution centre " No HP devices detected.' displays on the computer....
( Note :- When ever this message comes it means that the software is not installed properly or in other words you will be able to print but not scan.
To scan the Mapping between the printer and the computer needs to be very efficient so that if you try to scan from the printer it works fine. )
HP Solution centre Works With the following files running.
a:- HPQTRA08.exe
b:- HPQSTE08.exe
These files are mainly for scanning from solution centre on the computer.
*************************Troubleshooting steps********************************3
Initially, Since it could be a mapping issue as well check the connections.
Follow these steps to check the USB connections and product status.
1:- With the product turned on, unplug the power cord and USB cable from the back of the product. Wait 30 seconds.
2:- Plug the power cord back into the product.
3:- Press the Power button to turn the product on.
4:- Connect the USB cable back into the product, and then make sure that the USB cable is securely connected to the computer.
5:- Restart the computer
6:- Try opening HP Solution Center again: On the Windows taskbar,
click Start , point to All Programs , point to HP , and then click HP Solution Center .
If stil does not work then try next
[ Make sure that the HP Digital Imaging Monitor (DIM) is running ]
Step 1:- Look for the DIM icon in the notification area in the lower-right corner of the computer.
( If the DIM icon is present , discontinue the steps in this procedure )
Step 2:- If the DIM icon is not present, press the Ctrl , Alt , and Delete keys at the same time.
The Task Manager window opens.
Step 3:- Click the Processes tab, and then select the check box next to Show processes from all users .
Step 4:- Check whether HPQTRA08 and HPQSTE08 are running. If the services are running ,
Step 5:- If the services are not running,
There Are two Ways:-
Number 1:- Do this :-
a:- Click on start--> My computer--> C drive -->program files-->HP-->bin
( Or right click on HP solution Centre
on the Desktop and choose properties-->Click on the button Find target (XP) or Open location (vista).
This will take you directly to the bin folder. )
b:- In Bin Folder Find out HPQTRA08.exe and double click on it.
It will bring the DIM icon in the notification area in the lower-right corner of the computer.
The DIM icon should be initialised. When it is initialised it has a green check mark in the centre else it does not
notify it with the green check mark.
Number 2:- Do this :-
click Start on the Windows taskbar, and then click Run .
Step 6:- In the Open box, type msconfig , and then click OK . The System Configuration Utility window opens
Step 7:- Click the Startup tab
Step 8:- Under the Startup Item column, look for hpqtra08 (hpqtra08.exe) and hpqste08 (hpqste08.exe).
If these services are not in the list, the driver did not install correctly.
Step 9:- Select the check boxes next to hpqtra08 and hpqste08 , if they are not already selected, and
then click OK .
Step 10:- When prompted, click Yes to restart the computer
Step 11:- When the computer restarts, look for the hpqtra08 and hpqste08 services again
Step 12:- Try opening HP Solution Center again.
If still does not work.
Make sure all the services required for Solution centre to work should be running,
Click on start-->go to run-->type Service.msc click ok --> now Find out
HPQTRA08,hpqste08,pml driver and net driver services should be running.
Make sure that Pml Driver HPZ12 is running
Follow these steps to make sure Pml Driver HPZ12 is running.
a:- Click Start , Control Panel , Administrative Tools , and then click the Services icon.
b:- In the Services window, look for Pml Driver HPZ12 under the Name column, and then check whether
the status is Started . If the status is Started , discontinue the steps in this procedure
c:- If the status is not listed as Started , double-click Pml Driver HPZ12 .
The Pml Driver HPZ12 Properties window opens.
d:- Under Service Status , click Start , and then click OK .
e:- Restart the computer.
If still does not work uninstall the software completely. Call 1-800-474-6836
HP tech support.
on Jun 14, 2010 | Office Equipment & Supplies
Two different transactions from two different sellers were marked "Cleared" on my PayPal status. Transfers from my personal checking account to the PayPal account were completed on the same...
you can contact ebay on the hompage on the left hand side you will see a contact us tab click that another page will open with answer centre also eBay explained and security centre click on security tab another page will open on the left hand side you will see live help click that you might have to wait for someone to become available or you can talk to an automated voice explain in detail your problem with the live help you should get the appropriate help
if you paid using paypal
log onto your payal account open up a dispute in resolution tab you will have to find this tranzaction and copy the details down (date/item no/etc...(write them down) make a list of problems you have with the seller to make a claim
hope this helps
dont forget to vote
Feb 26, 2011 | PayPal Accounts
Laptop infected with worm.
Nortons sucks. you should try an anti-virus scan with Malwarebytes, then you should install Avast as your resident protection.
Be sure, when uninstalling Nortons, to use the uninstallation tool found on the nortons site. if you use the regular windows uninstaller, it will not remove all of it, and it will slow your computer down.
Dec 28, 2009 | HP Compaq Presario v3000z Notebook
Problems installing Nortons internet security
Antivirus Setup will be corrupted & it will creat this problem, Download new set up & try again. Switch of your firewall. I am also using a Nortan Internet Security.
Thanks.
Sep 22, 2009 | Symantec Norton Internet Security 2009
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
