Question about GE Spacemaker JVM1640SJ Microwave Oven
Replacement bulbs still do not work
Both bulbs in my GE over the range microwave oven JV1651WB003 blew at the same time. I replaced both bulbs with a 40 W 120V bulb. The replacement bulbs fail to operate. What is my next step?
  • fvbeerking Jul 14, 2008
    Thanks reg501, I'll try this and hopefully it'll work.
    fvbeerking
  • 413 Answers
Most electronic control boards have undersized circuit wires that can't handle a catastrophic lamp failure. The circuit trace will open like a fuse. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for open circuit trace.
4. Repair circuit trace...lights work again....
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 12, 2008
What light bulbs are for a Sharp R-1502 carousel microwave?
Hi,I would try (www.espares.co.uk),you can put the model in and it should give you the right lamp for your microwave,all the best.
Feb 05, 2018 | GE Microwave Ovens
While changing the light bulb under the unit, the wire connected to the light bulb holder touched the metal housing and totally blew out the microwave so it doesn't work.
normally there is a glass fuse in the circuit where the power comes in
check that fuse/ replace if necessary
As silly as it sounds --turn the equipment of at the wall before you work on it as it might have been you that blew and not the fuse
Jan 16, 2016 | GE Adora DVM1850 Microwave Oven
I have a GE JE2160sf01 Microwave oven. The oven blew the bulb and I have replaced it. Since replacing the bulb, the turntable will not rotate. I have checked and replace the motor, but still have the...
If you replaced the motor and turntable still does not rotate, either the motor is not receiving power or the the drive that turns the tt is not working because of slippage, etc.
Nov 08, 2015 | GE Microwave Ovens
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Panasonic genius microwave light bulb replacement The bulb on my Microwave model RMC275PD blew and no the microwave won't start, if I replace the bulb will the microwave work again? Thanks Richard
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
Aug 27, 2008 | Whirlpool RMC275PD Microwave Oven
GE Spacemaker Microwave (JVM1630BH003) hood light locked on
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If you or a friend decide to look into it further, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
181 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
