Question about Vizio L37 Television
Vizio L37 37 in. HDTV LCD TV
Hi Mike,
I am having the same problem, at first, it would come on for a few minutes, then cut off, now it does not come on at all. The light remains amber.
When you say the main card, are you referring to the card with all of the inputs? Did you install it yourself? If so, did you order if from Vizio and how much did it cost?
Thanks,
Bob (seedster@yahoo.com)
  • 2 more comments
  • taclark22 Jul 17, 2008
    i already have the back of the tv off and wonder if i can get a main board to replace the defective one... i get a blinking amber off light for a while, and when i try to turn on the tv it will come on for a few seconds, turn off, and the off light will blink again. it can't be that hard to replace; i just figure locating the part and coughing up another 200-300 bucks on a crummy tv would be a bad investment.
  • ragabnh Jul 18, 2008
    Turn on the Tv the amber light turns green, no picture or sound produced. TV is only 18 months old. If it is the main board, how much and where to buy.
  • Anonymous Feb 12, 2009
    I have the same problem it started cutting on and off on its own. Now my TV will not cut on at all. How do I fix it.
  • randytobie Feb 12, 2009
    I have a vizio VW37L, purchased in 9/07 that has the problem others described. TV has no picture, no sound, remote does not turn off. I have to unplug to shut off. Any reccommendations?
I had a similar problem with my Vizio Model VX37L HDTV and replaced the main board myself for $160.00 which I purchased new on Ebay at ShopJimmy.com. The symptoms all of sudden started by the screen going blank except for a rectangular banner across the top that resembled a UPC code only garbled. No sound. I actually had to pull the power cord to turn off the TV. I was able to turn on the set normally but the TV menus did not come up. Since the TV was 19 months old and no extended warranty I checked with Vizio support and Sam's Club but no extended warranty=no luck. I did have an estimate for repair for $900 from a company Vizio recommended but a new one goes for less now. About 42 screws and a half a dozen pin connectors I replaced the main board. The set is working again better than ever. I don't know if I call my self fortunate or not since I did have a problem after only 19 months.
Posted on Jul 19, 2008
  • Steady Eddie Jul 19, 2008
    I want to say THANK YOU to Fixya.com for the info I needed to repair my Visio VX37L myself. I hope my experience helps others.
How do you set up PIP on Model VX37L? (does it even have PIP)
Posted on Oct 11, 2008
EE_K
I have the same problem with the tv shutting off
I got a main board from ebay do you think that will fix the issue>
Posted on Jul 22, 2008
Vizio tv screen went gray
Hi Mike,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 05, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
We purchased a Vizio 42"
This is more of a provider problem. Report the signal problems to the service you subscribe to for tv.
Mar 23, 2011 | Vizio E420VA 42 in. LCD HDTV
My vizio tv with new dish network no longer recognizes all my inputs.. can you help
Hi rshowe610,my name is Mike Houston of DISH Network and I was going over your post and seewhere the Vizio TV is not reading the DISH Network receiver. There are a coupleof things to check first, you will want to make sure all connections are tightand secure. If you still notice the inputs missing from your Menu screen trychanging out the Cord/Cable of the missing input and replace it with anotherconnection and see if it reads it. If you still have an issue with the missinginput please let me know at michael.houston@dishnetwork.com.
Feb 20, 2011 | Vizio VW37L 37 in. LCD HDTV
Vizio tv hdtv lcd changes channels and makes the volume go up and down on its own.
I called Vizio when my TV acted up and was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in.
Hope this works for you, if it does, let me know by coming back and voting. Thanks!
Sep 11, 2010 | Vizio L32 32 in. LCD HDTV
After a few minutes the picture goes haywire and a loud high freq
Hello
This is a warranty issue. Either take the TV back to SAM's club or call Vizio for a warranty repair.
Jul 28, 2009 | Vizio L32 32 in. LCD HDTV
My Vizio TV screen cuts of heads.
have you tried pushing the "zoom" button?
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 42" LCD HDTV - sound went out
Same thing just happened to me contacted Vizio had me unplug the TV from the wall for about a minute and then replug and cut the TV back on and everything was fine. I have the television hooked into HDMI1.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 32 and Direct TV remote codes??
Oh Boy Good Day...code 10056 worked for me...FINALLY...have been searching codes for 17 months...cheers thanx ever so parseeker :))
Jan 15, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L37 Television Logo
745 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
