Question about Jenn-Air JDS8850AAS Dual Fuel (Electric and Gas) Kitchen Range
Igniters do not spark on one side of cooktop
Igniter does not spark on one set of two stovetop burners.
Four burner gas cooktop, two each side. I have swapped the two burners on the right, with the two on the left and problem moved with the burners. Disassembling the two non-igniting burners revealed no obvious problems. The wires are intact, I cleaned the contacts. Ideas?
Actual Model number is JDS9860AAW
  • 4 more comments
  • jdmccoy Jul 11, 2008
    Sorry forget to say, gas flows freely, just no spark. I can light the defective two burners using a match.
    The ignitors are on each burner. Appears to be a simple setup, a wire runs to each burner and the spark ignites the gas when the control is turned to ignite. All four burners originally sparked when any burner was turned to ignite. Now only two burners have spark. The wires appear in good shape, the ceramic housing around the spark point appears okay. There is no resistance between the contact point of the ignitor wires and the spark point, measured using my home meter.
    I do not understand how the ignitor functions or how to measure the voltage. The ignitor protrudes under the burner. When the knob is turned to start the gas flowing and ignite the flame, the ignitor sparks. It does not appear the the surrounding burner is grounded as I cannot get a zero resisance reading through the paint or whatever material is covering the metal. How should I measure the voltage?
    There is voltage on the non-functioning side, however, not as much as on the side that ignites. I do not know how much as my home meter jumps around. After shutting off the gas, and trying to get the spark, there is sometimes a small spark. If I remove the functioning two burners, the remaining two still do not spark.
  • jdmccoy Jul 12, 2008
    It is the wires! Thanks for the help.
    Thanks for the expert advice!
    Where can I purchase the wires?
    Champion:
  • 217 Answers
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Posted on Jul 11, 2008
  • 3 more comments
  • Mike Wright Jul 11, 2008
    Is the igniter mounted to the burners individually?
    It looks like you've been pretty thorough with this. When you attempt to spark, does the multi meter you have, detect any voltage coming through to the other end? (if possible without the gas on) lol
    All you would basically be looking for, is to see if the meter showed any signs of voltage hitting when the igniter should be sparking. As far as a ground... Is there an overhead vent/light setup installed? It should provide a good ground for you.
  • Mike Wright Jul 12, 2008
    I wonder if the integrity of the wires providing the spark is degraded... I'm sure what else to say. Are you able to swap the wires from the functioning burners? (just to see if it is indeed the wires)
    As far as getting replacement wires... You could try contacting the customer service for the maker of the grill. Or maybe bring the bad wires to a Home Depot or Lowe's. They should have them. Thanks!
Removing spark module viking gas cooktop
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
Apr 01, 2014 | Viking 37 in. VGSU161 Gas Cooktop
Cooktop burner do not ihnite
Hi hgodoy2 - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Nov 24, 2012 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
Jul 31, 2010 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
When you turn the burner on, it makes a popping noise and will not stop.
You're gas burner has an electronic ignition that you're hearing. Sometimes they can get gunked up and become sticky. If you have been using the stovetop regularly and this problem suddenly appeared, we can assume that the power grounding and polarity are correct. If this is all true, then an igniter or igniters are either wet or dirty. Unplug the electricity and thoroughly clean the burner pieces and specifically the igniters (little separate cylinder next to each burner) with a sponge or other non-abrasive dishrag and hot soapy water. Make sure all the burners and igniters are completley dry, plug unit back into electric outlet. If problem persists,call an authorized repair person as you may need 1 or more igniters replaced.
Good luck
Jan 11, 2010 | Viking Pro Series VGRT3626B (Gas)...
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Jenn-Air JDS8850AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
402 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
