Question about Ovens
Control panel disassembly
Have an electric Thermador wall oven/micro/warming tray SMW272. The oven display and timer/clock slowly faded to nothing. Bought new display and main power relay from Thermador but no instructions came with parts. How do you remove the control panel to change out the parts. No visible screws. Must I slide out the whole unit? Help
  • spam428 Jan 24, 2009
    cannot figure out how to get into front panel to replace clock / timer
  • Anonymous Mar 15, 2014
    how can I remove the front control panel on my Thermador C301U oven
Shut the breaker off to the oven first. Frame around mircowave is a snapped on front. Removing allows access to two screws under control panal. Must actually pull entire unit out about 9 inches to access top of control area to remove access panel. Once front control panel is removed and top is opened, easy access to what you need to get to. Carefully write down color coding of wires before removing any of them. Remove old power supply board and display and reconnect. Reverse process. A bit of work but if you watch the disassembly process carefully, pretty easy.
Posted on Jul 12, 2008
How to replace control board for thermador SMW272
remove oven from wall. remove top and replace from above.
Aug 29, 2014 | Thermador SMW272 Electric Double Oven
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Oven displays Off with every button you push
touch panel has failed . may need replacement . . this unit may require a update kit .. ( new p c control and panel .. ) very costly. mm
Jul 13, 2010 | Thermador SMW272 Electric Double Oven
Front panel light is fading
Had the same problem. Replaced the display board.
Apr 12, 2010 | Thermador SC302T Electric Double Oven
THE DISPLAY PANEL ON MY OVEN DOES NOT DISPLAY THE
replace defected control board.some of the cap on control board leak.
Jan 27, 2010 | Thermador SMW272 Electric Double Oven
Thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Sep 11, 2009 | Thermador SMW272 Electric Double Oven
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
491 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
