The bloe light turns on and the fan starts, then it all shuts off. I plugged it in and there is an orange light on it.
    Sergeant:
    Champion:
  • 307 Answers
Can you get to the bios setting, by tapping the del or f2 key as it boots. Sound like a power supply - If you feel comfortable take cove off, unplug machine first. Remove Ram boards and re-insert them, plug in and turn on. Ram connectors get dirty and will give you this proble. Also sounds like a Bios or CPU bad. There is a tester for the power supply which will give you the reading for its voltage. good luck.
Posted on Jul 11, 2008
M1160n wont boot windows xp nor two internal fans
Step 1:
Lets try this...
Unplug the cpu
Step 2:
remove the battery from on the mainboard
Step 3:
press and hold the power button for 30 seconds
Step 4:
release it
Step 5:
put the battery back in, plug in and turn on , it should work fine..
Step 6:
If that fails replace the power supply..
Dec 28, 2012 | HP Media Center m1080n (PC099A#ABA) PC...
Cannot start up the dell c521, fan is loud and light is orange.
What you are describing is a no post failure. Disconnect all external devices, see if anything changes. if not, replace the motherboard
Oct 28, 2009 | Dell C521 DimensionTM PC Desktop
When the computer is plugged in it doesnt work. The datech fan doesnt work. The front of the computer displays an orange light instead of green. If I replace the fan will this correct the problem
Replacing the fan as far as I know should not cause a light change but instead the computer would get hot shutdown every time he got too warm the orange light usually signifies a hardware problem. If you have opened your computer before you might have accidentally disconnected the hard drive or one of the cables from the motherboard. If the hard drive is disconnected that usually will get an orange light or if a ram chip is missing or not in all the way does a computer beep when you turn it on
Jul 27, 2009 | Dell Dimension 3000 PC Desktop
Dell Inspiron 530 boots then the screens turn off to orange light
Is the PC actually doing to sleep or is the display just amber with the fan and power light on the PC still running?
Do you have multiple video cards or multiple ports?
You may have the monitor plugged into the non-default port on your video card or the wrong card. Try plugging the monitor into another port as the PC should use all outputs when booting but then define a default display once the driver is loaded. Also take a look at the default video display in your BIOS settings. Depending on what your setup is you should be able to choose between (onboard, PCI, AGP)
Jun 10, 2009 | Dell Inspiron 530s Desktop Computer...
Dell 5150c shuts down orange flashing light
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Mar 16, 2009 | Dell Dimension 5150C (DIM515CMIN) PC...
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Mar 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
The power light keeps flashing orange
I had my Optiplex GX520 at work shut down abruptly every time I turned it on it in the morning. This would always happen within the first 30 minutes. I would then get the flashing amber light. After starting the PC again, it would stay on all day (over 8 hours) without shutting down again. I found that the power supply was over-heating.
Two things need to be done. First, in order to get the amber light to stop flashing, un-plug the computer from the wall for 30 seconds then plug it back in. OR hold down the power button for 10 seconds or so. The light should stop flashing. Then press the power button again and the PC should start.
But why did it abruptly shut down in the first place? The power supply has a fan-speed-control circuit in it to keep it running slow and quiet when the power supply is cool. It gives the power supply lower voltage when the power supply is cold and higher voltage as the power supply gets warmer. This circuit either is not working correctly or the fan getting sticky over the years and needing more voltage to get it moving when it is cold. I found that the fan was not starting at all and causing the power supply to over-heat.
To keep the fan moving at full speed, I cut the wire to it and wired it to the +12v output directly. Not the fan goes at full speed all the time. And yes, it is nosier. But at work it doesn’t matter.
The best solution would be to just get another power supply from Dell if possible. Or buy a +12v, 70mm fan from Digi-Key and replace the original.
Jun 27, 2008 | Computers & Internet
Gx260 pc wont start
Have you checked the post lights located in the back of the system by where the keyboard plugs in? There are is a row of 4 lights; either yellow or green. If the systems gets stuck at a particular post location, the lights will tell where. Good luck
Aug 16, 2007 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
