Question about Kyocera Office Equipment & Supplies
Cannot communicate with our KM4850-W via the web interface. I can ping the device, I can print to it via IP, but I cannot access it via a web browser.
  • tturner33 Jul 17, 2008
    Worldvet,
    Thanks for the response. The issue was not with the client web browser. The issue was hte hard drive in the 4850 that contains the web interface. The software cannot be reloaded, the hard drive must be replaced. We found a supplier for the had drive and the local dealer will install it. Thanks for your help.
  • Anonymous Mar 25, 2014
    DocuPrint C525 A-AP
    can't remember password for web interface via centreware
    Guru:
  • 859 Answers
Can you provide me with some more information we need to know to fully understand and fix your problem.
What Operating System are you on, what browser and what version are you using to connect to the web interface?
Does your IP enabled network printer connect into the system via a router or a switch.
What is the address you receive when you ping the printer? I know that may seem superfluous, but it will tell me what type of Network you are on.
And, just to verify the product you selected using our category selector you are attempting to connect with a Kyocera KM-4850-W, is this correct?
Thanks for your patience with what has to seem like ridiculous questions, but accuracy in understanding what and which printer we are talking about is more than just helpful, it will prevent misunderstandings and get you a complete answer sooner.
Thanks,
Worldvet
Posted on Jul 11, 2008
  • Glenn Rogers
    Glenn Rogers Jul 17, 2008
    Thank you for your reply. Naturally, I would have like to earn your support for a Fixed on this problem.
    I'm glad to hear that you have found the problem and have a repair path in place to get you up and running again.
    I'll use your reply to keep in mind should this occur again in the future here on our board.
    Again, thanks for rating, so many people don't and I'm sorry I couldn't have earned your regard for a fixed in this problem.
    Good Luck and please don't hesitate to use our service again in the future and we can help you more quickly with an effect response at that time.
    Regards,
    Worldvet
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Printer has stopped working and all lights on switch are blinking
Try to switch off and on the printer. Make sure you can ping the printer IP address. Check if you can access the printer via web-browser by inserting the printer IP address into a web-browser.
If all this work and only not printing. Check on the print queue if the port is configured to the correct Printer ip address.
Aug 30, 2010 | Office Equipment & Supplies
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
Zyxel220 can't be reaced via webbrowser
Here few things that you could try:
1. Try to check if there is a proxy server configured in your web browser. Tools>>Internet Options>>Connections>>LAN settings..>>make sure nothing is checked.
2. Disable anti-virus and firewall temporarily and check if you can access it using your web browser.
3. Possible that the IP address of your zyxel has a conflict with another device in the network (i.e. router,switch, etc)
4. You could also use firefox as an alternate browser.
Hope this helps.
Oct 11, 2009 | Zyxel NSA-220 (NSA220) Network Storage...
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Printer can not ping
is this is a print server/network printer? first off, the basics --- is the computer you are using to ping the printer on the same LAN IP as the printer (e.g. 192.168.1.x for both)? is this a wireless print server/network printer? if yes, physically connect it first to a router or switch and check if you can ping it. if you can, does it have a web interface, make sure you can access it and its wireless settings matches those of your wireless router.
Post back whatever you can come up with so I can give you more specifics
Jul 13, 2009 | Zebra (11X-7CX-XXXXX) (11X7CXXXXXX) Print...
Cannot telnet to SN0108 altusen serial over net
Please change the ip address to 192.168.1.32 or something and try telnet.  Thanks ,
Vipin
Mar 16, 2009 | Altusen 8PORT POWER ON THE NET W/ (PN0108)
Can not access web interface ''controller'' - Aprilaire 8825
aprilaire has tech svc google search and call them they are out of mich.
Feb 03, 2009 | Heating & Cooling
Wi Fi fine, ISP fine, no internet via LAN connection though.
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Jan 21, 2008 | NetGear DG834G Router
Not getting System Information Screen
BGP510-->PC....make sure computer getting correct default gateway as u said. if so, go to command-prompt and do ping for default gateway & see whether it is pinging successfully.
if it is pinging, then go to browser settings and clear the cache, history, temp files, etc., and Try again.
- If it is not pinging successfully, then it might be DHCP issue on the device ( BGP510 ).
- you may also try to assign Static IP on the computer to access the web-interface.
Hope it will fix your problem !!
Oct 01, 2007 | 8x8 Packet8
281 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
