56hm66 I have a shaded strip across the top of my screen. I read different solutions to this online and decided to pull the screen off to see if this is something I could fix myself. Well that wasn't going to happen, and when I put the screen back together, the picture is distorted like I warped the screen.
I have a shadow running across the top of my toshiba dlp 56hm66 the full width of the screen. It appears to be widening as time passes, it is almost 2 years old now. The shadow is streches down 5-6 inches from the top of the screen.I have a shadow running across the top of my toshiba dlp 56hm66 the full width of the screen. It appears to be widening as time passes, it is almost 2 years old now. The shadow is streches down 5-6 inches from the top of the screen.
AnonymousMay 11, 2009
i have a shade across the top of my screen... is fixing this easy enough to do it yourself? or should someone be called in?
You can't post conmments that contain an email address.
Sounds like COF (Chip On Film) strip fault. Check this link for more details. There is illustrations [screenshots] and reasons to plasma displays. Check it out, and compare them with your TVs fault. Pull up older posts there.
What I do is buy broken TV's on ebay of the model I need (very cheap) and strip for parts.
Sometimes it takes a few weeks before the model I need show up, but it usually does. If it is very urgent you should be ale to order it through any Toshiba Service center.
Hope it helps.
it's a faulty light engine. Toshiba usually does replaces those for free because they sold with a faulty part. Had mine replaced for free last year. Check your serial number on this page:
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts. Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks Richard Scott Technical Support New Zealand
Hello I cannot help you brighten the screen but I have a similar problem with my camera when I tape graduations and ball games. I have come up with a solution for me that can work for you as well. What I did was I made a small shade to put over it that works like an umbrella and makes it easy to read. See below \/
side view ------------------------- ---------------------------- } l l----Radio---------l l } l l } Shade ---->l l
If done so that the top and sides cast shade on the radio, you can clearly see the screen even in the sun.
I had the same problem on my tv found a simple solution its been a week and no problems so far.pull out light engine you will find round piece of tape pull it of there will be a #2 phillips screw in about 3 inches turn it clockwise and watch it vanish.i turned mine a little further to assure it would be gone.only took a couple of minutes to do dont know how long it will last though good luck
TelecomTech
jb
Repair Kit for Hitachi convergence Chassis DP-14G KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors: http://www.eserviceinfo.com/ http://www.digitalhome.ca/forum/search.php http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220 http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
i have a shaded strip across my screen.
