Printhead on Canon i850 indicated it should be repaired or replaced. I can do it myself (just took it out and cleaned). Where can I get a replacement printhead?
Found other info on net.
Posted on Jul 12, 2008
Printhead location unknown on a canon 850i printer is what the fault indicates
Check the contact area of your print head.. sometimes if ink get into the area.. it will give an error.
Make sure you clean the area behind the print head.. and see if there is any dirt or ink at the contact area on the printer, clean with some slight alchor ..
May 23, 2010 | Canon i850 InkJet Photo Printer
Canon i850 light is green then flashes orange 7 times then goes green and repeats orange flashing. Printer never gets ready
This is a very bad error. It means that the printhead needs servicing and may need to be repaired. There is no easy fix. Sorry.
Jan 21, 2010 | Canon i850 InkJet Photo Printer
How to deep clean the canon i850 printer? I took the black ink cartridge out to replace. Bought a new one but did not put the cartridge in for 3 months. Stapl;es said I need to do a deep clean now. And...
It's simple. Just use rubbing alcohol on a qtip. If you really want to do a deep clean, you can get a cleaner/degreaser. Look at Active Components website. It's safe on all rubber and electronic components.
Sep 30, 2009 | Canon i850 InkJet Photo Printer
Won't print
All the canon inks clean with just water, you need a new printhead.
Aug 11, 2009 | Canon i850 InkJet Photo Printer
Print head problems 7 yellow lights 1 green light, how do I fix
That's not a printhead problem, it's saying that the waste ink absorber is full. You need to have them replaced at a shop where they can also reset the waste ink counter.
Apr 13, 2009 | Canon i850 InkJet Photo Printer
Flashing orange lights
WASTE TANK NEEDS TO BE EMPTIED
GO ON LINE AND TYPE
CANON 850i INKJET PHOTO PRINTER 7 BLINKING LIGHT YELLOW
AND YOU CAN FIND YOUR HELP YOU NEED
ROD THE CANDYMANGNADY
Jan 14, 2009 | Canon i850 InkJet Photo Printer
Printer colours
by blue you mean cyan cart. It could be down to the print head bein glogged up, i would do some deep cleans and make sure the machine is purging ok, If not change print head, If not it could be logic board but i have never had it with the cyan colour only megenta and black.
So printhead so clear your fault
Aug 10, 2008 | Canon i850 InkJet Photo Printer
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Canon i850 7 orange flashes =Bad printhead????
I had the same problm the printer made loud noises, the head did not move and the light flashed orange. At the right most position where the print head rests there is a gear, gunk had the gear jammed I cleaned it with a paper towel lots of black ink came out, it is working fine for a couple of days now.
Apr 17, 2007 | Canon i850 InkJet Photo Printer
458 people viewed this question
k24674
jasbo
jasbo
