Question about Dometic Rooftop RV Air Conditioner
Where is the water from the condensor supposed to go, on mine the drip pan has two outlets on either side that go out onto the roof and down the rain gutter. Doe's that sound right. Thanks
  • jbrad89 Jul 12, 2008
    Thanks.
  • 828 Answers
Yes that does sound right.
Posted on Jul 11, 2008
Where are the condensing water drains?on a Coleman RV rooftop air conditioner
The condenser drains for a roof unit drain on top of the rv. There are on hoses which divert the condensation to a location other than the roof. Are you trying to keep it from dripping down at the door?
Jun 28, 2014 | Dometic Rooftop RV Air Conditioner
Not cooling
outside freeze sensor locking out operation
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
Water coming from aircon inside
Typically a blocked evaporator drain. Remove filter and inspect the drain pan which is below the radiator looking bit. Clear any obvious blockage around the outlet. Alternatively, find the drain outlet and blow back up it gently. This can be done with compressed air or similar. Take a photo of the indoor / incar unit and post it here if you are still stuck.
Dec 22, 2012 | Dometic Rooftop RV Air Conditioner
Why is water dripping in side from a/c ?
because the condensate drain is plugged with dirt...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Dometic Rooftop RV Air Conditioner
Red liquid dripping from roof of rv. Coming from AC where water usually runs.
Check that the drain pan is completely draining. If the drain is partialy plugged, you may get rusty water from the unit when the water level gets to the support brackets.
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Both units are liaking water inside coach. Have claned out overflo
Did you check & make sure drain holes were cleaned out in base of unit on roof? When you say overflow, do you mean drip pans under cover on roof unit, and if so, did you inspect them for cracks ? There were some years that experience cracks in drip pans.
Jul 11, 2009 | Dometic Rooftop RV Air Conditioner
My dometic RV rooftop air conditioner is leaking on the inside of the camper even after I cleaned the water condensation drain on top of the roof. What could be causing this? The fan is blowing the water...
Remove all covers and look down with them removed and see if the coil drain pan has a stopped up exit where the water drains out and into the rear of the AC unit.
If the unit is off level it could cause a draining problem too.
Jul 10, 2009 | Dometic Rooftop RV Air Conditioner
Collecting water on top of house boat from air conditioner
Thess units are designed to discharge the condensed water onto the roof under normal conditions. HOWEVER you should be able to have a sheet metal person make up a drain pan to fit under the unit.
You would ten need to add an additional gasket between the drain pan to roof and drain pan to A/C unit. The drain pan could have a hose connection attached to the drain pan. Try it, you might like it.
Also you may have to get longer screws to tighten down the A/C from below.
Jul 22, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
132 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
