Question about Saeco VIA Venezia
Saeco Via venezia
Thanks for your reply re machine does not turn on maybe fuse problem. I have found the boiler but dont see any fuses do i have to dismantle boiler or maybe there are in the on-off switch somewhere? Thanks once again you have been very helpful
  • onlinejourna Jul 12, 2008
    KaffeSumpen
    Thank you I think it was black though! Now working rating 100%!!!
  • mentis Sep 20, 2008
    my via venezia does not work
    where is fuse - I looked for a black and a light brown one without success
    wayne
Hi, Just a huge thanks to KaffeeSumpen, you solution was brilliant. My father and I were sorely upset that the machine stopped working but we then found this site and gently pressed the switch and voila, it worked! Excellent thank you so much again.
Posted on Jul 15, 2011
  • 74 Answers
No you dont need to dismantel the boiler.
the color of the fuse is light brown and for reseting it you only need to press it
Posted on Jul 12, 2008
  • KaffeSumpen Jul 12, 2008
    I am very glad i could help you.
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
Dear Expert, My Saeco VIA Venezia Problem is : Machine never comes up to Temperature (no Green Indicator Light), ie. doesn't heat and no pump. Like a fuse is blown. I have been told that there is a 'RESET'...
There is a fuse on top of the boiler. Its under a clip on the outside edge of the boiler. It is covered in a redish brown cover that you have tpo slide off to see the fuse. It is just better to replace the hole thing. If you don't have a pump also it could also be the switch. If you have any power its probably the fuse.
Nov 03, 2010 | Saeco VIA Venezia
Power light comes on. No heat and no pump
preview fuse located on the boiler,its looks like wire with diode,you can test with voltmeter,if fuse doesnt work make by-pass,connect two wires and taped with electrical tape,be carefull,good luck
Mar 02, 2010 | Saeco VIA Venezia
After months of perfect performance, my via
HI I think you have a blown element in the boiler. You might have a leak that is shorting inside also.
Jan 26, 2010 | Saeco VIA Venezia
Water does not get hot, no steam is produced.
Hi
It can be any of these. Fuse but then it would not turn on. Disconnected wire. More than likely it is the boiler element. Do a search on ebay for completed auctions. I saw a boiler assembly for a Saeco which is the same.
There are 6 screws that hold the top/back on.
Nov 20, 2009 | Saeco VIA Venezia
Water won't come through my Saeco via venezia coffee machine. It was working fine until I cleaned it so I don't think the pump has gone.
If the pump vibrates when trying to draw water then that is a good sign. Remo;ve the hose on the output side of the pump and turn it on to see if it draws water(BE Careful water and electricity love each other too much), it water flows out the output side, reconnect to boiler and test. If that did not solve the no draw problem then the machine is blocked either at the boiler.
May 11, 2009 | Saeco VIA Venezia
Via venezia Expresso
Perhaps you dont need to change a fuse. but only reset them :)
open up the machine and look for the boiler. on it are two automatic fuses that you can reset.
Hopefully its that otherwise it might be the powerboard.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Left power and steamer on overnight and now machine doesn't work
they have a heat fuse attached to the side of the pump so when you do what you did that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage to machine it not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and saw the heat fuse on the side of the pump,
Feb 22, 2008 | Saeco VIA Venezia
Overheat cutout switch
The coffe maker has a heat fuse attached to the side of the pump so when over heats that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage the machine if not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and noted the heat fuse on the side of the pump
Feb 10, 2008 | Saeco VIA Venezia
Saeco VIA Venezia Logo
218 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
