My computer tells me to connect to a usb2 port for faster transfer, how do i do this?
    Sergeant:
  • 329 Answers
Depending on the age of your computer, most new (2 years) have the USB2 ports. Try a new USB wire.
Posted on Jul 11, 2008
I keep getting message saying my pc will run faster with 2.0 hi-speed host. how do i get it
Hi! Welcome to FixYa!
USB versions are USB ver 1.1 and USB 2.0 and USB 2.0 has faster transfer rate.
When you're receiving this kind of message, that means you're using a USB device that is compatible with USB 2.0. This happens when you plugged in a USB 2.0 device to a USB 1.1 port on your computer. It simply notifies you that the USB device can perform faster when you have an available USB 2.0 port. I'm not really sure what kind of computer you have and what version of windows you have but you can actually check if you have USB 2.0 by going to Device Manager, click on Universal Serial Bus Controllers and look for "USB2 Enhanced Host Controller" if you don't have this, that means your computer has no USB 2.0 port. Hope this helps.
Jul 02, 2011 | Computers & Internet
My pen 4gb pendrive is working very slow it works 800kbps
When you plug in your USB pendrive into your computer and you get a message "This device can perform faster if connected to a high speed USB2 port".
This means your computer supports USB1 which is much slower than USB2 and the latest USB3.
There may be a BIOS upgrade to configure your computer to support USB2.
May 26, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Why has it got two usb cords and which goes where?
Hi scamp,
The specs on that HHD says that it has both USB and USB2, which are different in that USB2 transfers data much quicker than USB. If they are not clearly marked USB and USB2, try one connection and transfer a large file, switch ports and transfer the same file again to see which one is quicker.
Hope this helps...
Dec 29, 2010 | Memorex Essential TravelDrive hard drive -...
I insalled the software, but I can't get the videos from my camera onto my computer. When I put in the usb, it tells me it could perform faster in a different port but I've tried all my ports. I just want...
I think your PC is drawing attention to the difference between USB 1.1 and USB 2 ports, USB2 being much faster.
It wouldn't do this if you had USB2 ports on your PC.
Now working on the premise that your copying video tape to your PC rather than copying video files to your PC.
Other than rebuilding your PC or buying a new one will USB2 ports, you could
1) If its a laptop, use the firewire port. Just buy a firewire cable.
2) If its deskstop, buy a firewire PCI card (Not much, try ebay). You'll also need a firewire cable.
3) Carry on using the kit that you've already got, its just going to take a lot longer.
A final thought comes to mind, especially if the process is to copy tape to dvd.
I've have friends have no end of problems using these Dazzle and similar products in conjunction with a PC to make a DVD copy. The big issue being lip sync problems.
The way I prefer, and much more reliable is to daisy chain a
Camcorder/VHS recorder to a DVD recorder with a hard drive and finally a TV for monitoring.
Press play on the camcorder/VHS and record on the DVD player.
Once complete, edit on the DVD player and then write to DVD.
Jul 17, 2010 | Pinnacle Dazzle DVD Recorder
When i plug in my memorycard adapter into the usb ports .the baloon says i need a hispeed usb host controller.
The memory card you have is for a USB2 configuration and the USB port configuration or port you are using is USB1 configuration.
Try a different port or check the manual for port layout or description.
Sep 26, 2009 | DFI WB72-SC Motherboard
My computer does not read iomega hard drive
Make sure that your computer has usb2 ports. Older computer have usb1 ports. A 1 tb hard drive may require the newer faster usb2 port. If it is a desktop computer you can get usb2 cards or if it is a laptop you can get a usb2 converter. You may just have a driver issue. try the cd that came with the hard drive. Make sure your system is compatible.
Jul 01, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
USB2 ports on siemens C 1020
The USB Controller is too old and only handles USB 1.1
If you want to upgrade to USB 2.0 you can do what I did for my old gateway. I bought a USB2.0 PCMCIA card. You can pick them up for anywhere from 20 bucks on up, depending on how many ports you want. Best Buy has them so I would imagine any computer retailer would be able to snag one for you.
Hope this helps.
May 01, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Dell precision not recognising usb 2.0
sounds not,  some of the older systems only have 1.1, Usb 2 is not all that old (about 2-3 years).
you can upgrade to USB2 bu adding a USB2 PCI card to your system, this would give you some ports on the back and it may be possible to link the ports on the front to the new PCI card to upgrade those as well (depending on how they are connected to the mobo)
you can get USB2 cards with a Pin header which would allow for a pin block connection.
Oct 25, 2007 | Dell Precision Workstation 670 PC Desktop
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
