SOURCE: I've just got an ampkit
If you touch the area where the input and output level bars are (lower right of the screen) it will open a page called "Input Options".
Make sure the input and output gains are up about 75%. Usually the output gain is about 5-10% lower. If you're getting a button that says "No Input" where the input/output level bars should be on the lower right corner, it is telling you that your iPhone headphone/mic jack is not sensing the line from the Amplink. Leave everything connected, and exit the Ampkit program and then start it again. It should reopen with the level indicators showing. These connections are all finicky.
SOURCE: when the ampkit link is
Best in this case is to get in touch with the company - there should be an "Info" panel, and a Feedback section where you can contact them directly.
