Question about Compaq NC6000 Notebook
Keypads when pressed are not working
Hi, i purchased this laptop second hand and when i press a key it does not press, the slash key (/) presses itself continuously and also a very fast bleeping noise sounds. do you know what is causing this and how can i fix this problem.
    Genius:
  • 1,061 Answers
The beeping is being caused by the stuck key.You need to clean the keyboard.the keys can be popped off and dirt removed with a q-tip.wash keys with warm water after removal dry and replace.RICHARDM69
Posted on Dec 04, 2008
I just replaced the control board and now it won't reset
Hi try this. 1 press & hold the door alarm keypad. .2 press & hold freezer temperature down keyboard within 3 seconds. .3 release the door alarm alarm keypad and wait 3 seconds. 4.the control will DISPLAY PE to indicate the programming mode 5.entry is confirmed by pressing the freezer temperature down keypad once more. .6 the control will display the current program CODE this program should be validated with the program CODE printed on the unit serieal plate ..NOTE.IF THE PROGRAM code is correct the programming mode is excited by pressing door alarm keypad for 3 seconds. .7.press the refrigerator temperature up keypad or refrigerator down keypad to change the digit value with each key press. 8,. the decimal point indicates the selected digit press the freezer temperature Up keypad to select next digit. . 9.. Once the desired program code is entered press & hold the freezer temperature down keypad until the program CODE begins flashing indicating it has been saved.Note.if u attempt to enter an invalid code the control will not save the new code ...but will beep ,,(the unit will not run with a program code of 0000 ,). Once the program CODE has been saved the programming mode is excited by pressing any key.if the new code is incorrect this process should be repeated.the programming mode can be excited at any time by pressing door alarm key for 3 seconds or will exit if unattended for 4 minutes..good luck
Jun 16, 2016 | Maytag Refrigerators
F buttons description
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
Sponsored Links
Computer Repairs (Melb)
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
Sep 25, 2012 | Toshiba Satellite A100-S8111TD Notebook
How do you unlock the key pad on a Nokia phone
Hello
To unlock your keypad press the top left key on your keypad and the star (*) key on your keypad, this unlocks the keypad...
Apr 11, 2011 | Nokia 6085 Cellular Phone
Hi There. Not sure what key i've gone and pressed. The majority of the letters/numbers on my keyboard all work in first hand english but some of the keys where i have an option with a smaller blue number...
You have turned on the numeric keys on your laptop. It is turned off/on by the following.
Press the Num Lock key. If nothing happens, try Shift+Num Lock.
If the text Num Lock is shown in a different color, find the matching-color key, such as Alt or Fn. Then press that key in combination with Num Lock.
You’re successful when the Num Lock light comes on. At that point, the keyboard has switched into numeric keypad mode.
Read more: http://www.dummies.com/how-to/content/the-hidden-numeric-keypad-on-your-laptop.navId-323018.html#ixzz0vfEI4Odm
Aug 04, 2010 | Computers & Internet
My Inspiron 1525 comes on with the "9" lock(?) illuminated; it goes off while booting, and comes on. What is this "lock", is this "lock" important; what does it mean; and if I need to get it "unlocked",...
Ordinary "desktop" keyboards have a separate "keypad" (slash, star, minus, plus, enter, dot, and 0 through 9) in the same layout as a "traditional" adding-machine.
However, to keep the laptop's keyboard much smaller, those keys are superimposed on the right-hand side of the "standard" keyboard.
So, press "NUMeric LOCK" to use the "keypad" layout, and press it again to use the "standard" letters (I, O, P, K, L, M, et cetera) on the keyboard.
Apr 10, 2010 | Dell 0Y3740 Keyboard
How do you turn numeric pad off of a dell inspiron 1501
To enable numeric keypad, just press "NumLk" key.
Here is Dell Inspiron 1501 Owners Manual - if you have more questions regarding your laptop.
Sep 02, 2009 | Dell Inspiron 1501 Notebook
My lenovo keypad problem still not solved.When I press the key where two virtual keys are taken?For example when I press 'O' '6' are taken.My laptop manufacturer is LEnovo and model number Lenovo Notebook...
It seems that your Num key is active.So when you press any character then No are display .
To resolve this just keep on pressing the Fn key which normally left hand side of ctrl key ,Hold that key and then press the Num lock which normally togle with Delete key .
Solution :- Keep pressing Fn key + press Delete Key .Problem will solve
Mar 28, 2009 | Computers & Internet
Slash / sign and other symbols
Hold down the shift button and press the letter V. Everything printed above the letters on the background of the keypad can be printed by holding down the shift key and pressing they letter key.
Hope that helps.
Jan 24, 2009 | Dymo LetraTag QX50 Thermal Label Printer
How do you use the question mark
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Inspiron 1501 Notebook
Nokia 1100 keypad lock code
i have a nokia 1100 ,its keypad lock no not working / please advise me to unlock the keypad.....
May 03, 2008 | Nokia 1100
Compaq NC6000 Notebook Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
