Question about HP Photosmart C6180 All-In-One InkJet Printer
Empty ink cartridge message
The message 'replace empty cartridge magenta' came up. I replaced it. Message still appeared. Repaced it with another brand new cartridge and still the same mesage. Printed in black and white for a while but now won't print even in black and white
  • 9 more comments
  • Anonymous Jul 18, 2008
    I replaced the old cartridge with a new one (Magenta) and it still asks me to replace it with a new cartridge.
    For 1 colour which is LOW, it stopped me completely from PRINTING or COPYING at all.
    Any clues how to fix this?
  • willdrescher Jul 23, 2008
    I have the same problem and cannot fix it
    any ideas
    it is with my yellow ink and I have replaced it 2x with original hp ink and done a # reset too.
  • ldkeen Sep 08, 2008
    new ink cartridge will not register, printer will not print at all, keeps saying replace cartridge
  • Redleg89 Oct 06, 2008
    Have replace the yellow ink cartridge twice with new cartridges and it keeps telling me to replace yellow ink.  Any solutions?  This is irritating! And expensive!
  • Anonymous Oct 09, 2008
    Same problem...have replaced yellow toner twice and it still doesn't print in color, black only
    October 2008
  • vtreitler Oct 15, 2008
    same exact problem. i almost never print in color. i was asked to replace the yellow cartridge - i did that, and it will not register that the thing has been replaced.
  • Anonymous Oct 17, 2008
    My printer says that i need to replace three colors and they are not empty.
  • sandyjmiller Oct 29, 2008
    I have the same problem with my yellow cartridge. I have only had the printer for two years and have done very little printing on it, so I sure don't want to purchase a new one!
  • tmmcntsh Oct 30, 2008
    i have the same problem. I replaced yellow cartridge and it still says replace cartridge. I have also had the printer for 2 years.
  • Anonymous Jan 03, 2009
    2 years old. yellow cartridge error.
  • mr peanut Jan 03, 2009
  • 26 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457329&cc=us&lc=en&dlc=en&product=1153494
use this
Posted on Jul 18, 2008
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I am getting a message "CM Ink Empty" can you advise what this means please
Hi there!
The message CM ink empty means that the cyan/blue and magenta/pink ink cartridges are empty and needs to be replace.
Hope this helps. Thanks
Mar 31, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink empty yellow error message even after ink has been replaced
the mechanism on the cariage is faulty. It cannot be repaired by you the user.
Jul 08, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
390 people viewed this question
Ben Johnson
