Question about LG LF-U850 Shelf System
Volume raised by itself
My stereo has raised the volume up by itself a couple of times, sometimes all the way up to the max. Does anyone know what the cause might be? I purchased it not even one year ago.
  • Anonymous Apr 22, 2009
    Same for me! Any ideas?
    Problem Solver:
  • 12 Answers
Did you ever get a solution to your problem ? I have the same problem, I called Customer service and they wanted me to reset the unit by just unplugging it for 40 seconds (and holding down the power button while it was unplugged) which didnt seem like a way to reset it to me, since all of my radio presets were still there. it did it again yesterday, the volume all the way up. The Cust Svc person (who im sure is not a tech) said she had never heard of this problem and said I could send it in for service for $69 plus parts. (not worth it.) email me back if you found out a better solution, i just found the resetting by unplugging didnt work for me. jen21090 @ yahoo . com
Posted on Jun 28, 2009
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
2009 Hyundai Sonata decreases volume by itself
Do you have the AVC (auto volume control) enabled? If so, disable it and see what happens. If that doesnt fix it, try to do a "hard reset" by pulling out the shunt fuse. It's 1 or 2 fuses in a little yellow thing in the fuse box on the inside driver side, just pull it out a little, not all the way. Your dome lights, door dinger ect should stop working as well, this is normal. Wait 5 min and push it back in, hopefully that'll fix it up.
May 30, 2012 | 2009 Hyundai Sonata
Volume automatically decreased to zero and won't go back up.
Plug the audio out to check it isn't the speaker itself failing. I suspect it is the audio circuit section of the board. But a few times I have experienced the speaker unit circuit where the magnet is caused the problem. So using an external speaker helps to determine speaker vs circuit
Thanks for using FIXYA
Oct 11, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I cannot raise the volume level.
Plug the iPod into you computer. Open iTunes and click on the device on the left. View through the settings to find the volume limit controls. then move the slider to Max.
Aug 04, 2009 | Apple iPod classic MP3 Player
No sound on viewsonic VG730m
you have to connect it via audio cable.
you need a cable with two 3,5mm stereo jacks. this you have to connect with the stereo output of your computer (mostly the green one) with the audio jack on your monitor. it's somewhere on the back i think. sound / volume control you do in windows - its the same as if you connect normal stereo speakers to your computer.
(perhaps you have to unmute or to raise the volume in the monitors os menu)
Jul 23, 2009 | ViewSonic VG730M LCD Monitor
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Problem with volume in player
Every mp3 player manual has a disclaimer that says not to play it at max volume - the only workaround is to get adjustable headphones, and keep player volume at less than max
Jun 18, 2007 | iLO (2 GB) MP3 Player
Open Questions:
LG LF-U850 Shelf System Logo
177 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
