Question about Philips DVP-3005 DVD Player
Password issue I was trying to find the Auto resume function on my dvd, I guess I accidentaly set it to ask for a password before running a DVD, and I don't know how to get rid of it, since I don't know if there is a password or not. Now I can't get it to play any DVD and I can't find a reset function. Thank you
  • sharwill20 Sep 10, 2008
    the disc lock is activated and I can't figure out how to unlock it.
    Brigadier General:
  • 6,966 Answers
Pls try a full master reset which if done correctly would revert the unit back to factory default:
1. Power on the unit;
2. open the front panel lid to have access to the controls;
3. simultaneously press and hold the channel up and down buttons;
4. wait till "BYE" is displayed;
5. wait till clock switches off;
6. power on again and re-configure.
You may need to restore "Region Free"
1. Power on the DVP 3005.
2. Bring up the System Menu.
3. Navigate to the Preferences page.
4. Press the following combination of keys on your remote in this order to bring up the secret menu showing the Region Code.
1 3 5 5 6 6.
5. Use the arrow keys on the remote control to change the Region. To make it region free, set the Region code to “0′ (zero).
6. Exit the System Menu.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 11, 2008
Hi i'm vicky from mauritius, i have a car dvd model nddn w 58 in my toyota passo sette asks me a password , i just import from japan when i remouve the battery the dvd player ask me the password
Vicky, usually you will have to contact the manufacturers or distributors, they will then take your details & match them on their data base, then they will give you the code.
May 08, 2012 | Car Audio & Video
Phillips 3040 dvd player is asking for a password and I don't remember setting it for a password. How can I get past the password?
Try using the password 136900. If this works for you, then using your remote, go to the general set up menu and select the Disc Unlock option.
Hope this helps!!!!
Jan 08, 2011 | Philips DVP3040 DVD Player
I can't remember the password on my Toshiba laptop!!! It's running Windows Server 2003, and for pete's sake i can not remember the admin password I setup for the laptop. I haven't used it for awhile, is...
Go to the safe mode :- Leave admin password empty if asked.
And then click on start-->run-->type cmd-->type control
userspasswords2 hit enter--> windows open's here --> on the top uncheck option for ask user name and password before entering windows. and then hit apply.
let me know if it works.
May 10, 2010 | Computers & Internet
Administrator password Dell Inspiron 1720
If the system is asking for an administrator password in Windows and you are wanting to format and reinstall the system, then the password shouldn't be an issue. Most inspiron systems are equipped with a PC Restore partition CTRL+F11 just after the Dell Splash Screen should enable the restore process. If PC Restore doesn't work, then boot to the XP CD and format the NTFS partition and install Windows XP clean. If you have Windows Vista, the PC Restore is run from the F8 Boot menu. If no restore partition is accessible in Vista, then again Boot to the Vista DVD and format the NTFS partition and install VIsta.
Sep 30, 2009 | Computers & Internet
Parental lock on cannot open it
Actually its, 'select' then '7444', and all that does is reset the password.
Press the SELECT button and enter the 4-digit number "7444" whenever the Parental Control display asks you for your password. The old password is deleted.
You will then be prompted to enter a new password, enter whatever number you want, something like 0000, or a number that is easy to remember. If you wish to turn it off, just set it to off and forget about passwords.
Notes
- When you play DVDs which do not have the Parental Control function, playback cannot be limited on this player.
- If you do not set a password, you cannot change the settings for playback limitation.
- Depending on the DVD, you may be asked to change the parental control level while playing the disc. In this case, enter your password, the change the level. When you stop playing the DVD, the playback limitation level returns to the original setting.
After changing DVD settings:
To save your changes, be sure to eject the DVD before pressing the RESET button or turning off the unit with the MAIN POWER switch. Please note that changes will not be saved if you reset or turn off the console without first ejecting the DVD.
Sony Playstation 2 manual, pg. 19
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
Need default password for phillips dvd
default passwords are usually 0000/1111/1234 etc. try looking in the users manual for the starting code.
Jul 23, 2009 | Philips BDP7200/37 Blu-Ray Player
RE CHANGING REGIONAL CODE FROM US - AU
Yeah I could not find the manual myself. Email Zenith with details on the problem, ask them:
A reset procedure or a Master Password for the system password, without password you cannot change regional settings.
A copy of the user manual possibly in PDF sent into your Email.
With the master password you change old password and regional settings.
Zenith customer service answers within 24 hours.
Jul 17, 2008 | Zenith DVP615 Portable DVD Player
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Philips DVP-3005 DVD Player Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
