Question about Minolta DiALTA Di620 All-In-One Laser Printer
Error code C-14F2
Upon starting machine gives C-14F2 code. I believe that's a filter problem. I removed the cover and cleaned all the filters I could find but it didn't help. What else can I try? Thanks in advance for the assistance!!
  • Minolta Master
  • 6,359 Answers
Check the filter operation and harness and, if they are okay, change PWB-IB or PWB-IC meaning check the connections one board B is located under the scanner C is located behind the scanner, get tech to this is is going to get complex open close front door to reset.
Posted on Nov 22, 2015
2 Suggested Answers
firecontrol7
  • 6359 Answers
SOURCE: upon turning on the machine, machine display error
M4 is maintenance counter, you clear it in service mode.
Posted on Jul 19, 2009
Samsung fully automatic washer-dryer machine model : WD-B1255 i cant open its door and it keeps giving me "5 and a 3 but looking in the opposite direction" what can i do the clothes is stuck in their
The code your machine indicates means that the debris filter needs cleaning. To do this remove the plug from the electrical supply. Using a coin open the filter cover door at the far bottom right hand side of the machine. You should see an orange coloured plastic tab, pull this forward to open the door.
Warning: If the drum still has water above the door seal it will pour out when you open the door. If this is the case there is an emergency drain tube to the right of the orange tab, pull on the tube and place it in a shallow container. Then remove the rubber plug and drain the water from the machine.
When the machine has been fully drained open the debris filter cover (large circular plastic plug to the left of the orange tab) and remove any soiling/rubbish that may have accumulated there. When complete push the drain tube (with rubber plug back in position) back into the machine, replace the debris filter cover, and then pop the filter cover door back in place. Hope this helps.
P.S Removing the plug from the power supply also resets any error codes so that should remove the error you had as well as being a safety precaution.
Feb 07, 2016 | Samsung Washing Machines
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
I have an error code of nd on my washer
If your washer is beeping, and the display is flashing "Nd", your debris filter may be clogged. To check for a clogged debris filter, goto back of machine, look for little door at bottom remove cover and remove filter and clean
Dec 19, 2010 | Samsung WF306BHW High Efficiency Front...
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
What does error code f14 mean on a zanussi bwm129
I believe that is a indicator of flooding of the machine. I also believe if you remove the bottom front panel you will find a sheet of paper with fault codes. While the front panel is removed, unscrew the cover on the water pump filter, check for restiction.Have a shallow pan to catch water and towels to absorb water that will be present
Nov 07, 2009 | Washing Machines
Getting an F 02 error code with my Kenmore Elite HE 3T
Your filter on your pump is probably clogged with lint and other stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Filter in aqaurius 1000 washing machine
Depending upon which model you have, the filter can be be found in 2 different locations.
First, if there is a removable plastic cover at the bottom front of m/c, then remove same, and see if the filter is there.
If it is there, then unscrew plastic cover anti clockwise, remove and clean filter.
If no filter there, then remove lower rear cover of washer, locate large black hose at lower right ,remove clip and hose, remove plastic filter and ball inside ,and clean.
Be careful as there will be water run out.
Refit filter and hose securely, test for leaks.
Plz rate my solutrion.
Thanks.
Jan 16, 2009 | Washing Machines
Machine Fault Error No 06 at start up Model is Krups XP7240 Expresso - not listed in product list
The error 06 (comes after start up) and machine in auto test - happens because more than one problem. One of the compulory services, rinsing, change water filter, cleaning OR / AND descaling is out of date. Start off with one at a time and do ALL.
Reconfirm it by going into "Product Information" and confirm that the cycles since previous cleaning, descaling and water filter replacement is ZERO.
Your machine will NOT have start up problems any longer
Regards
Jul 10, 2008 | Krups XP4030 Espresso Machine
F-21 error, washer not draining
I have had this code three separate times. The first time service man came and cleaned out the filter. This is behind the lower front panel and can be removed by hand. The cartridge style filter is located at the pump in the lower right of the unit. Have something available to catch the draining water as you loosen the filter. The second time I received this code I found a blockage in the drain hose at its bend. The third time no hose blockage, no filter clogging, but the pump impeller was jammed by an elastic strap that had made it through the filter. I removed it through the supply side of the pump seen after filter is removed.
Feb 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
112 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
