Question about Dryers
It works but the drum doesn't spin - Dryers
    Novelist:
  • 177 Answers
Sounds like a broken belt
Posted on Jul 12, 2008
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
Drains but drum wont spin
see this probably causes:
t spins, but doesn't pump
see for glogged drain line
It doesn't spin or pump
see the pump pulley frozen
It pumps, but the water returns
slow drain, improve the drain see the attachement
May 08, 2012 | Washing Machines
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My LG front loader washer stops in the middle of it washing with the error code LE. For some reason or another it sounds as if a screw is loose in the drum or something in or near the drum is off cause it...
"Lock Error"
The fault code suggests that the lead that runs to the door interlock switch is faulty, has come off or is loose (Probably the latter by what you describe). I can't inagine how this intermittant error could be linked with what sounds like an item stuck in the drum.
For the item in the drum, I have sucessfully removed screws and the like by thoroughly draining the machine then turning it onto its face, supported by enough bricks or other items to allow me to have the door dangle open. Gently spin and rock the drum back and forth and let gravity do the work. It doesn't always work, but it often does.
Jun 28, 2011 | Washing Machines
Dryers Logo
61 people viewed this question
Top Dryers Experts
