Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp light (lite the color red)
Hi! I just replaced what I thought was a bad bulb, and after checking the light comes on for aprox 15 seconds and the turns off and after 20-30 seconds, the red lamp light comes on. Could this be a bad ballast? A tv repair facility advised me it could be the color wheel. Thank you for any advice,Greg
  • DannTheeMann Aug 10, 2008
    I have a mitsubishi also and then the # is different from that 1 but,
    we have a problem with the red lamp button and then it just popped up
    but the tv sound works but not anything else, got any suggestions for me?
    and would it be a bad lamp or something? do i gotta get it replaced?
  • Mitsubishi Master
  • 8,617 Answers
Chances are its the bad capacitor issue on the power pwb, These symptoms will mimic a bad ballast. You can get a repair kit for the V26 PWB PCB at the following link which contains the replacement capacitors and a CD which identifies the board and capacitor location that needs the capacitors changed and also contains the Service manual on that CD, and the entire kit costt less than just the service manual anywhere else. They have free tech support to help you with the repair as well. Heres the link the kits are listed under the repair kit catagory.
http://servicemanuals.vstore.ca/
Posted on Jul 11, 2008
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Replaced bulb but tv comes only comes on for about 10 to 15 seconds then shuts down and red light flashes
It sounds like you have a bad ballast board, or possibly the power supply going to the ballast bulb. I'm afraid that if you do not have the repair experience on solid state TV sets, you will need to contact and authorized Mitsubishi repair center. Good Luck
Jul 09, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Replaced the bulb on a 50ML8105D/17, the bulb starts to light but turns off at 5 seconds and the red led light on the front comes on.
Hi,try to reset lamp timer by unplugging tv wait 5 min and plug it back again.Check for clicking sounds it could be the ballast which is the board that powers the lamp that it could be bad.God bless you!
Oct 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
