Question about HP Compaq Presario V5000Z Notebook
Internet connection light
I did not have the laptop for several months. When I attempted to connect to the net, I found it would not respond. It seems to me that there was a light that came on when it was connected. It ain't. Isn't there a button I am supposed to push? I lost the instruction book which was very good. Thanks.
  • 38 Answers
Help & Support has everything that's in the owner's Guide. Just ask it.
Top left button, above the keyboard, is Wireless On/Off.
If nothing happens, go to CONTROL PANEL / NETWORK CONNECTIONS. R-click on Wireless Network Connection. L-click DISABLE. Wait about 5 seconds, do it again and L-click ENABLE. That should reset the modem and get things going.
After you establish an internet connection, go to START / PROGRAMS / HP / HP (SOFTWARE) UPDATES and install the latest patches. They will include aa newer version of HP Wireless Assistant
Good luck.
Posted on Jul 16, 2008
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
I have installed my reliance data card on my laptop, but when I am trying to access internet using this It is showing me Error 718 : Remote computer not responding. Please help me,
i am using reliance net connect broadband..it is working well on the computer.. but yesterday i bought a new laptop and when i tried to use net..it is showing the 718 error..that the system did not respond in the limited time...i uninstalled it and installed it twice! but i still cannot connect it! plz help..
Aug 24, 2010 | Computers & Internet
The tech tells me that something is blocking my firewall. I cannot connect to the internet. I have a Acer Aspire connected through Net Gear router. He wanted to charge me 130.00 to tell me how to unblock...
Try resetting the router by unplugging it from the outlet and from the modem.Also reset the modem by unplugging it for a few minutes also.After you do that it may take several attempts for it to reconnect with your laptop.
Aug 24, 2010 | Acer Aspire One PC Notebook
Keep losing wireless connection
probably not your computer problem
probably its the net
does it happen every where' or in singal net?
Oct 01, 2009 | IBM ThinkPad R52 Notebook
Mercury USB laptop connector with AT&T Service
try connecting with a cat5 cable instead of using the wireless. It is possible your problem is your wireless connection and not your service provider. Make sure your ether net connection is not disabled.
Sep 06, 2009 | Sierra Wireless Aircard 860 PC Card...
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
On my PDA MC70 it is showing WI-FI "unavailable"
This can get kind of complicated, and your wireless carrier may block this depending on the data plan. It's also different for the MC7095 (CDMA) and MC7094 (GSM/GPRS) models. You may also want to see if your device BSP release is up-to-date.
Here is some basic info for the MC7095 (Sprint):
Device was not connected to network to start.
Went to Start, Programs, Internet Sharing, tapped Connect, showed Status: Check USB connection. Internet Sharing drivers were installed on laptop computer, then device displayed Internet Sharing Status "Connected". We were able to browse the web on the laptop computer. Closed out of Internet Sharing (tap X on upper right hand corner). On device, tapped Start, Internet Explorer, attempted to browse to a webpage. Able to browse on both laptop computer and MC7095 device.
Note: Attempted to Disconnect the Internet Sharing session, unable to. The device does not appear to respond to the "Disconnect" option on bottom left of screen. When tapping "Disconnect" the option light up as if being tapped however the device itself shows no other changes and Status still displays :Connected.
***FYI*** In testing with a different MC7095 (BSP33) we experienced the same issues with not being able to "Disconnect" the Internet Sharing session.
Jan 29, 2009 | Symbol MC70
Wireless connection works and then disconnects itself
look for a program on the web called Net Stumbler
It should be here http://www.stumbler.net/
That will show the signal level from your router.
I have seen this before and it could be several different problems
1. Someone else on your channel
2. Burned out ant or output section in the router
3. Broken Ant wire in laptop
Hope this helps
Jan 02, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
HP Compaq Presario V5000Z Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
