My ac unit has about 2" of water around the base of the unit in the metal pan it its on. I'm wondering how at happened and what I can do to get my ac working again
  • 95 Answers
There should be a condensation drain line on the bottom of the air handler. Check this drainline, for sludgey build-up. If you find the drailine is plugged, clear the opening and vacuum out the pan and line.
Posted on Jul 11, 2008
Bosch dishwasher will not take in water after cut off and restore of external warm water supply. Pump runs, aqua stop slightly warm and red tap /faucet signal comes on. Tried tilting.
your dishwasher is leaking water. the bottom or base of the unit is like a big catch pan, the pan has a water sensor witch is two metal contacts positioned just over the bottom of the pan. As water from a leak begins to fill the pan and makes contact with the two metal tabs it opens the circuit to a cut off switch at the water inlet valve. Slide the unit out from the cabinet just far enough to access the sides, about 20 inches, As water is removed from the panand no longer making contact wit the water sensor power will be restored to the inlet valve, Now you begin looking for the source of the leak, You may need to start a wash cycle, this is why the unit needs to remain connected. The source of the leake will dictate what needs to be disconnected and position of the unit. Something like the water level sensor can be replaced without fully uninstalling the unit.
Aug 18, 2015 | Bosch Dishwashers
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Water drips into the camper through the foam rubber air intake, after it runs for awhille
Sounds like your drains for drip pan under the evaporator area are plugged. They are located at the base of the AC unit on roof. Look real close under AC unit near front, for a hole in base plate of AC on each side. Water ( condensation ) should be dripping out of those holes pretty steady when running.
You should have an inch or so clearance between base of AC and roof to try and get a bent piece of wire, or similar in to hole and try to clean it out. If that doesn't help you will have to remove plastic cover and remove all the screws that hold the front cover over the evaporator and remove the front metal cover. Look down at base of the coils and fins and you will see a drip pan that has small holes at each end for drainage. They will get plugged up with debris, thus poor, if any drainage. I use a long air nozzle and a small compressor to blow them and the tray out to clean it well. That will usually cure your problem. Please remember to shut all power to AC, off at breaker panel before removing the cover on roof to avoid electrical shock.
Sep 04, 2011 | Dometic 57915531 Air Conditioner
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Water leaking around screw of ac vent in bedroom. it is a slow drip that is constant even when the ac shuts off
From what you described, it sounds like the drain hole in the condensation pan under the unit is clogged. Also, the unit may not be titled down enough at the rear of the unit. Generally, 1/4" to 1/2" is required, so that the water in the condensation pan will flow to the rear of the unit, where the drain hole is. These 2 things are where you need to start troubleshooting.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | Heating & Cooling
I have a window model and lost my user guide. I was wondering where the water empties?
There's a drain pan under the unit. I has a drain hole on the outside (outside the wall) part of the AC. If the unit is installed properly and has a 1/4" to 1/2" downward tilt on the outside, the water runs to the rear of the drain pan and drains out thru the drain hole. That's assuming the drain hole is not clogged.
Jul 19, 2011 | Haier Heating & Cooling
Water leaking from base of unit during operation
dehumidification is something that AC units do as a by-product of cooling so yes, it is acting as a dehumidifier. there is a coil (copper tubing snaking back and forth through metal fins like on a radiator) that water condenses on and drips off of. That water will fall in to a pan and then will either evaporate or run through a drain. Make sure the path from the coil to the drain pan is clear. The water will either drip down (pan sloped to a corner or hole) or run through a tube to the drain pan. The drain pan is the part that had the drain plug in it. If that pan was dry the condensate is reaching the pan. If it is full that means either the drain is plugged up or the unit is pulling humidity out of the air faster than it can evaporate. Check to make sure any drain tube is clear and that the path for the condensate (water) is sloped the right way - not shaken loose or tipped to the wrong side.
That should get you started. Let me know if I can be of any other help.
Good Luck!
May 26, 2010 | Haier HPC07XC6 Portable Air Conditioner
Water dripping inside camper from AC unit
Basically there are holes in the base of the AC that allow water (condensation) to run out, that may be plugged, and usually you can tell by how much run-off you have on your roof, and the stain will also guide you to where to poke with wire to unclog. Best way to be sure is to take all the screws out around base of cover & lift cover off. Just watch for bees, or wasps before you do, they like to nest in there..If all unplugged & running out good but water still coming in trailer, then you may have a cracked drain pan.
Aug 08, 2009 | Dometic Rooftop RV Air Conditioner
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
